______ on odo mean cannot see pcm.
1 check fuses
2 check pcm for water try swap pcm
3 check wireing to pcm. Is pcm getting power. Check for damaged wires check earths
Hi, I need help with this Ford Focus,(no communication with ecu ) sometimes comunications with other units but no read errors, immo light blinking with ignition switched, on the odometer only ----- what at first check, all sugestions welcome.
Thanks in advance.
You use srs units files at your own risk. I am not responsible for any damages. Don't ask about passes, one file=one pass.
If I helped, please, use magic buttons reputation+thanks.
Best regards.
Dragon
1 check fuses
Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
dragon100 (30th August, 2017)
Hi!
I suggest to check soldering behind dashboard connector.
No, it was bad earth near fusebox under the hood ...and wires ...
Best regards.
Dragon
norman1967 (22nd September, 2017)
