    Feb 2016
    Default KTM 990 950 649 adventure dasboard speed correction
    hello my friends,
    i use my bike to some events and KTM as an option to use a tripmaster on the odometer, that is fantastic, but as you know all odometers have an error. so when using a roadbook that is not very helpfull
    however this odometer as an option to change the wheel size (it measures on the wheel) and for each wheel it displays the size in mm of the wheel.
    i beleive this information should be stored on the L56 chip and i would like to change it for example changing the 19'' wheel to the correct wheel size im MM (like bicycles) eliminating the error. however HEx is not my strong language and i believe that someone here should be able to help me out for sure.
    cheer's mates
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Mate dont start same thread again and again, wait untill some one respond your thread....................................
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
    Feb 2016
    this is not a repeated thread is it? i dont recall putting in other like this one
    Aug 2016
    Default here is 990
    hello
    u can see in service manual can change 17 or 19 "
    i ever see this problem before not correct mileage are not right
    second is different different
    i change dash problem is solve
    here is sample file 990
    do't forget my thanks
    Feb 2016
    Quote Originally Posted by bob1620 View Post
    hello
    thais dump is from a post 2008 bike this is a pre 2008
    i know you can change the wheel size the problem is that all vehicles come with a error from 4%-10% on the odometer and i want to correct that error on the odometer adjusting the wheel size in MM (when you change 17 to 19 you see in the bottom the wheel size) bu i dont know where it could be found on the l56 chip eeprom
    Aug 2016
    U MEAN WANT TO CHANGE 17 OR 19 ON L56
    IF THIS I DON'T KNOW
    I ONLY MAKE IT NORMAL BY OEM PARTS
