smirnoff_rules (9th January, 2017)
hi guys,
bad news...
my client decided to buy a brand new egr for his octavia 1.6 tdi
so, no pcr2.1 flashing over obd port.
he will be back in 6 months , make sure its from the agent they have updated this a few times
pulsar2000 (9th January, 2017)
ODIS can't update any ECU without car, key, dashboard....
ODIS cant write the same update number, only high number of update.
file to download sgo, frf .... for all VAG
https://vag-flashinfo.kluthr.de/index.php
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
catala20032004 (21st February, 2017), darkoman (3rd June, 2017), HeXeN (11th January, 2017), nickolasd (13th February, 2017)
kitnoos2002 (10th January, 2017)
HOT/COLD START
TRANSLATE DAMOS ENG
START/STOP ON/OFF
LaraVAG it's right about not be able to flash on bench with ODIS. It's possible if immo off or immo not active. Since you have ECU on bench immo is active (blocked) and ODIS will not let it Flash.
But you are not right about not be able to write same version or even older one. This I have done, and I'm 100% sure. But you have to uncheck option in:
Administrator\Functions configuration\Flashing (Engineering)\Activation version control
At least I was able to do it with my version. It's possible also that depend from version.
__________________
If You Like My Post
Please use the button on the LEFT side and the button on the RIGHT side.
Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
smirnoff_rules (11th January, 2017)
If X17 it's working, then KESS V2 will have it in next update or very soon. I can't wait since I hate to open those ECU-s.
I have try to test your method on bench today. But since I was unable to Flash it with ODIS I will try some test to rewrite ori file with KESS V2 on bench and try to unplug at about 80%. And then I will try to recover with mod file.
Will see what happens.
BR
__________________
If You Like My Post
