Col19 (19th January, 2020), dritan (18th February, 2017), gazvts (18th February, 2017), HeXeN (19th February, 2017), smirnoff_rules (18th February, 2017)
denso or delco ?
Col19 (19th January, 2020), dritan (18th February, 2017), gazvts (18th February, 2017), gezame (18th February, 2017), konq100 (18th February, 2017), moky (21st February, 2017), smirnoff_rules (18th February, 2017), stanislav georgiev (21st February, 2017)
IMG-20170220-WA0006 (1).jpgEDC17C50---BMW F SERIES ECU.
HAD ONE TO DO TODAY...OPENED THE ECU TO FIND THE PROCESSOR ON THE GOOD SIDE...USED THIS PICTURE TO READ THE PASSWORD (WITH NO BOOT WIRE ATTACHED---AND 12V POS ON K LINE).....THE CONNECTED TO BOOT PIN WITH NORMAL MPPS/FGTECH RESISTOR..AND READ/WRITE THE ECU NO PROBLEM.
MAGPRO X17--AT-200--SCANMATIC BENCH--PCMFLASH--MITSUBISHI MUT-III---OPENPORT 2 MMC FLASHER
Col19 (19th January, 2020), dritan (20th February, 2017), extremebike (21st February, 2017), gazvts (20th February, 2017), maybach_ (21st February, 2017), moky (21st February, 2017), pulsar2000 (20th February, 2017), rafal (15th August, 2019), smirnoff_rules (21st February, 2017)
simos pcr 2.1 R/W obd ok
was unlocked few months ago with ktag
Col19 (19th January, 2020), dritan (21st February, 2017), dustin2014 (21st April, 2017), gazvts (23rd February, 2017), smirnoff_rules (21st February, 2017)
Ecu Selection = Volkswagen Passat 2.0 TDI Siemens PPD 1.X
Bosch Hardware Number: 03G906018CD
Vw Software Number: 03G906018CD
System Type Number: R4 2.0l PPD1.5 G
R/W OBD/CAN = OK
blackpirate (2nd March, 2017), Col19 (19th January, 2020), dritan (23rd February, 2017), dustin2014 (21st April, 2017), moky (23rd February, 2017), smirnoff_rules (24th February, 2017)
Ford Fusion Style 1.6 TDCi Bosch EDC16C34-2
Software Number 1 : 1037377399
Software Number 2 : 1037377399
Ford Hawdware Number : 9653239880
Ford Software Number : 5255A56D10
Ecu Type : BOSCH EDC16C34/2.2
R/W OBD/CAN = OK .... after write not error OBD scaner.
dritan (24th February, 2017), konq100 (25th February, 2017), smirnoff_rules (24th February, 2017)
pulsar2000 (24th February, 2017)
Has anyone successfully used mpps v18 on win7 in VMware? I know the original will not run. Wonder if it works or if there is a common work around.
Read written FLESH + MPC + EEPROM fiat marely 6f3, OK through OBD.
There are few tools that read-write EEPROM marely by OBD.
OBD-flash reading 3min 20 sec., 45 sec-writing.
MPC and EEPROM read OBD-20 seconds, 20 seconds writing (multyboot OBD) .A very strong and stable tool.
fgtech2,bdm100,MPPS V12, galletto 1260,fiat ecu scan, vagcom,elm327,mobydic for fiat,MPPS V18
dritan (28th February, 2017), konq100 (27th February, 2017), smirnoff_rules (27th February, 2017)
Fiat Stilo IAW6JF.P3, through OBD, mpc and eeprom read write for immo-off, all ok.
multyboot OBD
I have a problem with my mpps reading vag edc17u01 by boot
Ecu identify perfect but when I press read and star to read but give me this error, anybody has this problem??
