MPPS v18 GOOD OR NOT? - Page 40
Page 40 of 50 FirstFirst ... 303536373839404142434445 ... LastLast
Results 586 to 600 of 746
  1. #586
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Quote Originally Posted by fabiof1 View Post
    Latest question....
    Mpps v18 Europe ( Carprog eu )
    what is better clone :
    kess v2 5.017 / or / Mpps v18 ......
    I would like Your opinion .
    I saw last week one kess v2 ""EU clone " from car prog, it looks just like China red kess , I think it is a China clone Reworked, eu clone are indifferent, on the eu clone you don't have green or blue led , you have another pcb , I don't know what to say , last week one friend buyed from car prog and it is China!!!
    Trimis de pe al meu SM-G930F folosind Tapatalk
  2. The Following User Says Thank You to DR Race For This Useful Post:
    Col19 (24th December, 2019)
  3. #587
    Member fabiof1's Avatar
    Jan 2012
    Yes real clone Europe it is good.
    but kess v2 or mpps v18 when it is better ???
  4. #588
    Kess has more cars but MPPS is much more stable in cars that it can do...
  5. The Following User Says Thank You to OVERSPEED For This Useful Post:
  6. #589
    Jan 2012
    Ok thanks.
    And only read ecu edc17cp14 with obd it is possible ? No risk ?
  7. #590
    Dec 2010
    Quote Originally Posted by OVERSPEED View Post
    and mpps is better recovery mode
  8. The Following User Says Thank You to vasco fernandes For This Useful Post:
  9. #591
    Jan 2012
    Ok thanks for your opinion.
    I'll try to read an edc17cp14 by obd ...
  10. #592
    nbtechnic's Avatar
    Jan 2016
    Warning: the use of clone mpps with risk and peril, I already made the expense with this clone tool. I give up its use. Here is my bad experience: ecu blocked with mpps v18 clone: edc16c34, marelli mjd8f2. Yet it worked well when I bought it, I'm disappointed ... I bought 2 new ecu for my cars.
  11. #593
    Jan 2012
    clone china ? Eu pcb purple ? Or Carprog ?
  12. #594
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Quote Originally Posted by nbtechnic View Post
    That 2 ecu have bdm on board !!! how can you kill it by obd ? you need more practice and then no need buy 2 ecus!
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
  13. The Following 2 Users Say Thank You to boomeer For This Useful Post:
    nbtechnic (28th February, 2018), sevid (6th June, 2018)
  14. #595
    Jan 2012
    Strange Yes... how it happened?
  15. #596
    nbtechnic's Avatar
    Jan 2016
    When writing ecu, the usb connection to move, writing to failed
    I made an attempt of recovery with the MPPS, at the end of the writing the cars did not start anymore,
    I try by bdm but ecu does not respond, that's why I decided not to use the mpps china.
  16. #597
    nbtechnic's Avatar
    Jan 2016
    With the new ecu, edc16c34 by obd and boot pin + BDM; marelli MJD8F2 by JTAG; I now use Fg v54 (test with 0386 and 0475) without any problem.
  17. #598
    meteor80's Avatar
    Does someone have solution to repair MPPS V18 with "waking up ECU error"?
    Program starts,
    Voltage recognize OK.
    But no communication with ECU.
    Work is a primitive way to spend Your free time.
    F.Kiepski.
  18. #599
    nbtechnic's Avatar
    Jan 2016
    all these problems leads me to think that the mpps is planned for a certain number of use, after this number to exceed it does not work, but without which one realizes it ...
    mine also worked very well at first, until he made me believe he was doing a recovery my ecu, but it was completely wrong.
  19. #600
    here there
    Any advise on wich model is best? red pcb or purple pcb? ive seen red pcb is cheapper than the purple
