X17 works perfect without open ECU.
If you have clon Kess you can do it to:
1. read oryginal file by OBD2
2. do your modification
3. correct CRC by genuine WINOLS
4. use ODIS, VAS, VCP
5. search FRF to this ECU
6. write FRF ( update software like in service )
7. when you have about 80% write software, disconet tool.
8. Now use Kess V2 recorvery and use before your file with CRC ok.
Now you know how to no open PCR2.1
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
Artilect (11th January, 2017), Col19 (19th January, 2020), datapage (7th January, 2017), Faraday (7th January, 2017), impuls002 (19th July, 2017), jnoroeste (26th January, 2017), kitnoos2002 (7th January, 2017), morfej (7th March, 2017), Novik_UA (8th January, 2017), ohkarol (7th January, 2017), vasco fernandes (6th January, 2017)
Person with clone Kess would not own geniue winols I would say
So non genius winols would not fix checksum or ?
kire106ka (6th January, 2017)
Fiat Doblo 1.3 mjet mjd6f3 obd - r/w ok
Range Rover edc17cp11 boot - r/w ok
this tool looks great
HOT/COLD START
TRANSLATE DAMOS ENG
START/STOP ON/OFF
Yes VAS, ODIS, VCP, VVDI, ABTRIUS can recorevery this ECU by FRF file.
HOT/COLD START
TRANSLATE DAMOS ENG
START/STOP ON/OFF
anyone know where to get some older frf files for odis
off topic again, i have installed odis-e 5.0.14
tomorow i'll have to do skoda pcr2.1 but it has in 2015 last update.
can be done by obd?
i'll try to do photos
it will work only with frf file?!!! no sgo\sgx?
but first, need to find frf file for that ecu, it has 3 updates untill now, injectors problems.
With ODIS Engineering you can write any file you want. I have downgrade EDC17C46 also without any problem.
BR
S
__________________
If You Like My Post
Please use the button on the LEFT side and the button on the RIGHT side.
Tuning, EGR, DPF, AdBlue, DTC, TVA, Speed Limit, Immo...
cristim (8th January, 2017), kitnoos2002 (8th January, 2017), morfej (9th January, 2017), smirnoff_rules (8th January, 2017)
