Page 43 of 50 FirstFirst ... 333839404142434445464748 ... LastLast
Results 631 to 645 of 746
  1. #631
    Jan 2014
    Ro
    fiat ducato mjd8f3..read write obd ok..write 2 min
  2. The Following User Says Thank You to tarabostesul For This Useful Post:
    Col19 (24th December, 2019)
  3. #632
    Faraday's Avatar
    May 2012
    The dark side of the moon
    This is well known that MPPS will f-up CHK on m-ed-c17 ( I mean clone)
  4. #633
    Jun 2012
    Someone has tested on Fiat / Alfa 1.4 multiair Marelli iaw 8gmf?
  5. #634
    May 2018
    Does anyone have any experience with MPPS V18 EU Clone with Peugeot 308 1.6 hdi 109 PS 2010 year 9HZ- Bosch EDC16C34
    Can you safely read and save by Obd?
  6. #635
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    hi, does anyone handle it to read and write direct over OBD a Mercedes-Benz BOSCH ME 2.1 (there is NO round connector under the engine cowling)....
    does I have to connect PINS on OBD port...?
  7. #636
    v18 deletes injector codes on marelli fiat&opel 6O3 , 6O2 even when only ID
  8. The Following 2 Users Say Thank You to donesko For This Useful Post:
    Col19 (24th December, 2019), SALAS (27th June, 2018)
  9. #637
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    that happens to me to...(lost injector code-easy to fix with mes if you already have read the code first) on marelli 6F3 with clone mpps v21...can't read flash... get error , read only eeprom and micro, very fast for obd tool... i am afraid to test it in other car, the only thing i have in mind now is the battery voltage.... i want to try with charger on battery, the tool shows me ~12.40v but mes ~11.60v maybe that is the problem....
    i test it in the same car and let you know..
    Quote Originally Posted by donesko View Post
  10. #638
    Nov 2018
    anyone has a pinout (tricore) for MPPSv18 clone for BMW EDC17 ? (read that you can use them same as ktag)
  11. #639
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    You can use pinout from fgtech galletto ......
  12. The Following 3 Users Say Thank You to Panathaole For This Useful Post:
    101newbie (6th January, 2019), Col19 (24th December, 2019), figani (8th December, 2018)
  13. #640
    Jun 2012
    Quote Originally Posted by dudus8 View Post
    NO PROBLEMS !
  14. #641
    Aug 2016
    Hi ,
    How to r/w Simos 8.5 Audi ?
    Thks.
  15. #642
    figani's Avatar
    Feb 2018
    I used V18 for a Magneti Marelli Fiat 6F3... on bench... multiboot option...
    flash... successful...
    mpc... successful...
    eeprom... failed...
    open it and read it by Ktag... and compare it...
    v18 corrupt data from eeprom...
    read 5 x eeprom by V18... everytime another result...
  16. The Following User Says Thank You to figani For This Useful Post:
  17. #643
    Jun 2012
    Eeprom can change for different dtc stored.
  18. #644
    Aug 2008
    LV
    Hi, mpps18 Grey boot wire where is connected on odb2 socked side ? my china cable is not soldered
  19. #645
    teerak2uk's Avatar
    Apr 2009
    East Anglia
    Quote Originally Posted by fricker View Post
    On 4 or 5. .
  20. The Following User Says Thank You to teerak2uk For This Useful Post:
    fricker (15th December, 2018)
