Page 24 of 50 FirstFirst ... 14192021222324252627282934 ... LastLast
Results 346 to 360 of 746
  1. #346
    Aug 2016
    Quote Originally Posted by svnsv View Post
    Eeprom R/W and Flash R/W on VW Golf EDC15P worked perfectly with 70? V18 from eBay.
    Looking forward to test some other ECUs in the next weeks.
    Was this with the OBD connector or boot mode?
  2. #347
    Aug 2015
    basement
    Quote Originally Posted by jameswalker View Post
    OBD while the ECU was installed in the car.
    A programmer went to the grocery store. His wife said "while you are out, go get some milk." - He never came back
  3. #348
    Mar 2010
    Europe
    Renault SID305 BOOT sak1766 read - write Ok. Checksum need winols.
  4. The Following 2 Users Say Thank You to Yura123 For This Useful Post:
    dritan (1st February, 2017), gazvts (31st January, 2017)
  5. #349
    Dec 2015
    Romania
    Hy guys this i'm me....
    Wtf is copy my video with youtube....
  6. #350
    Dec 2015
    Romania
    Quote Originally Posted by smirnoff_rules View Post
    cheeky Chinese using this thread as reviews for there mpps
    http://obd2all.blogbaker.com/categor...ecu-programmer
    I'm flash my car with mpps v16 only for test....
  7. #351
    roth18's Avatar
    Dec 2009
    US
    ...anyone figured out how to read TCs with password in BMW DMEs ? Password known of course.
    Best Regards, Roth.
  8. #352
    Faraday's Avatar
    May 2012
    The dark side of the moon
    VW PCR 2.1 doesn't work v18 clone
  9. #353
    filutek's Avatar
    Aug 2009
    Silesia
    V18 EU
    It works perfectly with PCR 2.1
  10. #354
    Dec 2012
    Smirnoffrules did pcr china clone ?
  11. The Following User Says Thank You to gazvts For This Useful Post:
    smirnoff_rules (3rd February, 2017)
  12. #355
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by Faraday View Post
    mine does no problem, first one l tested , also read and write on bench too
    you see pictures of mine all over china selling sites
    but its more work than you need ktag is so easy and alot faster . l dont use resistors
  13. The Following 4 Users Say Thank You to smirnoff_rules For This Useful Post:
    Col19 (19th January, 2020), dritan (5th February, 2017), gazvts (3rd February, 2017), pulsar2000 (3rd February, 2017)
  14. #356
    Mar 2008
    birmingham
    pcr2.1 unlock with mpps china clone version 1
    heres the pinout for this , i found how to do afew months back
    standard wires
    the second pin at the bottom left is kline green wire with mpps
    now this is how you boot ecu without resistors.. but you might want to try resistors
    unlocked here
    writing eeprom here after unlock
    tested with kess too
  15. The Following 8 Users Say Thank You to smirnoff_rules For This Useful Post:
    Col19 (19th January, 2020), dritan (5th February, 2017), ecutuners (5th February, 2017), gazvts (5th February, 2017), gezame (18th February, 2017), norman1967 (5th February, 2017), pulsar2000 (8th February, 2017), rob h (9th April, 2018)
  16. #357
    Mar 2008
    birmingham
    worded better with 15v tho , but that might be the clone
    now turn off power leave pinouts on remove boot pins and read and write on bench on obd , its a fast way to do this ecu , just tested and unlocked and locked the same ecu 10+ times with no problems , think l will use this on the next one l get in
  17. The Following 11 Users Say Thank You to smirnoff_rules For This Useful Post:
    angelx431 (6th October, 2017), bonux (20th April, 2017), Col19 (19th January, 2020), dritan (5th February, 2017), ecutuners (5th February, 2017), Faraday (5th February, 2017), gazvts (5th February, 2017), gezame (18th February, 2017), moky (5th February, 2017), pablo1971 (11th February, 2017), twchnodictator (9th February, 2017)
  18. #358
    Jul 2010
    italy
    I mpps v18 china.tried on MJD6 and really perfect
  19. The Following 4 Users Say Thank You to extremebike For This Useful Post:
    Col19 (19th January, 2020), dritan (7th February, 2017), koziolek (7th February, 2017), vasycara (8th February, 2017)
  20. #359
    Jun 2012
    Anyone tried a Peugeot 407 2.0HDI Delphi DCM 3.4
    had one in yesterday, list for mpps same car but DCM 3.5
    Id ecu ok, but security access Fail on read,
    i got the fgtech out, and all ok,
  21. The Following User Says Thank You to pulsar2000 For This Useful Post:
    dritan (8th February, 2017)
  22. #360
    Jul 2010
    italy
    second test of MJD6 via obd
    READ: MPC e2p and Flash.
    but lost injectors codes
    question : having read the e2p , the injectors codes are visible in hex?
