First you need start update ECU by Service Tool (it will unblock Eprom to write any file) next use Kess V2. To update by service tool you need car.
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
Guys....can we keep it on topic please....MPPS v18.....discussion
blackpirate (11th January, 2017), Col19 (19th January, 2020), doctore (19th January, 2017), filutek (11th January, 2017), gazvts (16th January, 2017), PremierD (11th January, 2017), pulsar2000 (11th January, 2017), shooting (11th January, 2017), vasycara (14th January, 2017)
Hello, I buy a mpps v18
I am waiting for delivery within 15 days and more
After the test I would tell you my experience with the mpps v18.
dritan (15th January, 2017)
Corsa D 1.3 CDTI, EDC17C18, 70.0kw,2010, Z13DTE R/W bootmode TriCore™ = OK
After unlock Tprot10 in boot, can I use Kess to write by OBD or just MPPS can write it ?
GOLF V 1.6 FSI, MED9.5.10, OBD/CAN R/W ( 30 minutes) = OK
Good tool
Wysłane z mojego LG-D855 przy użyciu Tapatalka
sonique (21st January, 2017)
Well mates, I started this topic and got the mpps so now I can share my results, finally.
Seems to be everything ok. Tried on edc15,16,17 and denso opel. Everything works very good and without any problems. Only once program said good bye and turned off during reading edc16 VW via obd, but I think it was WinXP problem. After installing win7 x32 everything works like a charm. Also according to your posts I think it's worth to buy it.
Col19 (19th January, 2020), gazvts (19th January, 2017), pulsar2000 (20th January, 2017), vasco fernandes (19th January, 2017), vasycara (20th January, 2017)
Today I did Insignia 17cp19 TC1792 in boot mode.
Mpps processor recognized as the TC1766.
Read OK I compared with Galetto.
But when writing badly counted checksums. The car was in safe mode.
Record Galetto solved the problem.
He met with something like that ??? Mpps v18 EU
TC1792 i do not see listed in manual processor selection
dritan (20th January, 2017), filutek (20th January, 2017), smirnoff_rules (20th January, 2017)
So, everything is clear. Mpps does not support the TriCore ....
gazvts (20th January, 2017), smirnoff_rules (20th January, 2017)
Yea that could of ended badly aswell
ecutuners (20th January, 2017)
I have done edc17c19 in mpps tricore bootmode several times. Doesn't show tc1792 but functions are exact to tc1796.
i would try using EU sw as checksum was done by tool on them all
Kess v2 FW 5.017 full unlimited token - Ktag 7.020 full unlimited token
ALL EDC17/MED17 EEPROM CHECKSUM + VAG IMMO OFF BY EEPROM - NO SAFE
EDC16/17 POPCORN - ME7/7.5 ANTI LAG - LAUNCH ALS/NLS
DPF EGR DTC SCR, Custom Tuning, Damos Translation, FRF / SGO Files
Professional Engine Software Development
Col19 (19th January, 2020), datapage (20th January, 2017), dritan (20th January, 2017), filutek (20th January, 2017), pulsar2000 (20th January, 2017), smirnoff_rules (20th January, 2017), vasco fernandes (20th January, 2017), wiseman (2nd February, 2017)
