Engine Tuning 101 / Discussion Thread... - Page 3
Page 3 of 12 FirstFirst 12345678 ... LastLast
Results 31 to 45 of 179
  1. #31
    Oct 2016
    I think this is great. Everybody tunes different cars and finds different things.
  2. #32
    Oct 2016
    Hi I'm wondering what software is best for tuning denso ecus through obd2 port. Specifically Toyota Hilux kun26 1kdftv d4d models years 2006 to current with 175800-8471 denso number on ecu and Toyota Land Cruiser 1vdftv. I have kess v2 software and can't access either. Do I have to purchase ktag and do ecus on bench or does fgtech work through obd2 or a different software.
    Cheers
  3. #33
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    try with magpro x17....
    inside forum:ask me about...i will tell you all that i know
    make me working for you...i will give you my paypal account
    outside forum:
    chiptuning,egr,dpf,add blue,dtc,Eu clones
  4. #34
    Mar 2016
    RO
    Default Citroen C4 1.6 HDI 90HP without DPF
    Citroen C4 1.6 HDI 90 HP without DPF with EDC16C34 . Made a WinOLS project with all the maps that I've found
  5. The Following 16 Users Say Thank You to AGDiag For This Useful Post:
    ali kaptan (25th November, 2020), bimmer36 (18th March, 2018), Eddie034 (27th November, 2017), iskogen76 (8th January, 2018), jameshal18 (6th May, 2019), jovanzac (2nd October, 2018), mexanico1971 (2nd October, 2018), mihai99 (25th January, 2018), morfej (5th November, 2018), nabilahmed (10th March, 2021), oscarcorra (11th October, 2018), ovidiumarin (25th February, 2019), s2000 (30th January, 2018), smifos (5th May, 2022), yanni8 (18th September, 2023), YASS59 (29th December, 2020)
  6. #35
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by AGDiag View Post
    andwhatis"phaseofinjection"
    i don"t see nothing more than ECM maps id here
    outside forum:
  7. #36
    Mar 2016
    RO
    @teamtuner as I said in a thread that I've started a few days ago, I am a newbie when it comes to tuning. That is a project that I've made for my own car because I want to learn more. I am aware that those are only a few maps, but for the start I am studying only the ECM maps. Regards to the "phase of injection" map, I found some information in this last days. I think it is a EGR map and I should have on the X-axis the IQ, on the Y-axis the engine speed and on the Z-axis the mass air flow. I've put that map in my WinOLS project because I found it on the ECM Titanium program, but I'm not sure if it's correct. So please, if you can correct it do so.
  8. #37
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    yes is the egr map...and this is your egr info
    outside forum:
  9. The Following 4 Users Say Thank You to teamtuner For This Useful Post:
    AGDiag (24th October, 2016), limenger (26th July, 2018), whalla (26th June, 2017), YASS59 (29th December, 2020)
  10. #38
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Quote Originally Posted by teamtuner View Post
    And it is wrong...
  11. #39
    Mar 2016
    RO
    here is the solution that I have found
    @bobolin4o why is it wrong?
  12. #40
    bobolin4o's Avatar
    My comment was for the PDF, in your file, EGR hyst. are marked ok...
  13. The Following User Says Thank You to bobolin4o For This Useful Post:
  14. #41
    Mar 2016
    RO
    if I modify my "phase of injection" map wich was determined that is the EGR map by modifying all the values on the Z-axis with the max value found in the original file, won't that be an EGR Off solution too?
  15. #42
    bobolin4o's Avatar
    The short answer is - NOPE!
    You will get the DTC - "insufficient flow"...
  16. The Following User Says Thank You to bobolin4o For This Useful Post:
  17. #43
    Mar 2016
    RO
    ok. thanks for your answer!
  18. #44
    teamtuner's Avatar
    May 2015
    TRANSILVANIA
    Quote Originally Posted by bobolin4o View Post
    And it is wrong...
    Bobo...is about
    how to close egr...like this from pdf...if egr is not blocked opened and if is ok,will see egr closed with diag tester
    not how to cancel egr disconected
    outside forum:
  19. #45
    Feb 2014
    Spain
    Look at the hysteresis maps selected in the pdf. They are in a wrong way. Not marked good.
