For sure you have a faulty press sensor or wiring problem, do you have Inpa ?? i so check wiring from inpa
Hi to all!
I have a problem whit the car from the topic.The airconditioner dosn't start.When i connect the diagnostic <ICOM and LAUNCH>
i get this error code (E718 Message <status of pressure,refrigerant cirquit,0x2D2)faulty,receiver IHKA,transmiter JBE)
I mesure the pressure sensor voltage and it have 5v and on the third cable i see 1.73 V so i thing that the sensor is working
i mesure the signal cable from sensor to the module under the dashboard and the cable is OK!!!
So if anyone have some ideas i will be very thankful!!!
CVN FIX Vag/Bmw
Tuning Petrol and Diesel
High Power Maps
Custom Tuning Stage 3+ Hybrid
Dsg Tuning
No friend i do not have INPA but today i will purchase new sensor to try
but i already check the wirings and i think that they are OK.Thanks
i change the sensor and the same think no Airconditionig when i read datastream i do not see any refrigerant pressure
do you have any fault code regardes to a/c ?
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
yes in IHKA i have these trouble code that i mentioned so i think the problem is in any of these two modules
Sent from my SM-G920F using Tapatalk
send me the codes and vin for the car and itry to help you,
CVN FIX Vag/Bmw
High Power Maps
Dsg Tuning
hei Rusinov87 have you read engine ecu code issues if you do please post it .
DTc(E718) Message <status of pressure,refrigerant cirquit,0x2D2)faulty,receiver IHKA,transmiter JBE)
WBAUG51080PW50689
Sorry to bring this thread alive, but i'm having the same problem. Has anybody fixed this problem? What can it be?
