Results 1 to 5 of 5
    Default ABM Missing files - Cable
    I am trying to set the cable tuner up using ABM but not having much joy
    I have installed the ABM cable tuner ran it and get error message's that I am missing files (see photo's)
    netid_filter.txt
    netid_unsorted.txt
    netid_sorted.txt
    nit_transponders.txt
    The dvbsnop is there / found
    I have a solo 4k box with 2 sat tuner and 1 cable tuner all enabled netid 00010 Teesside (this is not listed so i run with 1st area found
    DK Veteran lincsat's Avatar
    Jun 2008
    That is NOT ABM, it's LraiZers AB for C2. Are you sure that you're tuned to a Cable channel
  3. The Following User Says Thank You to lincsat For This Useful Post:
    martin035 (16th September, 2016)
    I have a channel list for cable the channels are darked out and i get that message when doing a scan - any thoughts / ideas?
    Jun 2008
    Are you tuned to a cable channel when you do the scan. Try tuning to the Virgin Preview channel and then using the AB 4 C2
    Sep 2016
    1) Which receiver are you using? And image?
    2) Under tuner configuration, have you entered correct network id?
    And finally it looks as though your not using Auto Bouquet Maker
