Hi everyone I have a Citroen Jumper and Fiat Ducato 2.2fiat.rarcitroen.rarcc with the same markings files and bin is corupt can someone help with immo off
delphi 01336569080 Bosh 0281010345 this dump from delphi immo
thank you very much for your quick help a reporting later mate
not work can you help me with another dump
Do you have dump from Immobilizer delphi 01336569080
Solved tnx very much
One day someone will need dump from Immobilizer delphi 01336569080 delphi 01336569080.rar tested immo off for ecu use from baltazar3 will work like rocket
93lc56 8pin, 256 Bytes
Fiat: Ducato2001-2006
Citroen: Jumper2001-2006
Transponder Type: Megamos Crypto 48
Programmed Transponder and the Created Image File Will Start the Vehicle
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
thanks, friend, i just need to write the dump, on imobox?
doctore (16th February, 2017)
rokibar (16th February, 2017)
s'il vous plaît aide please pass
Hi got this ecu with reference
Bosch
0 281 010 345
With flash and eprom 95p08
Please I need tested immo off
Envoyé de mon HTCD200LVW en utilisant Tapatalk
0 281 010 345 what SW?
need help
now my goal is to buy xp-005
who will help?
