Results 1 to 15 of 17
    Feb 2016
    Red face CarProg Airbag Toyota 89170 B2C60 89170 52J30
    Can anyone help me to find the Update for CarProg
    below the Unit IDs
    89170 B2C60
    89170 52J30
    Version CarProg V9.31
    SN :081105CAR001773I
    lib file attached 081105CAR001773I.rar
    Jul 2014
    post your files here and someone will help you to clear them
    Cheers
  3. The Following User Says Thank You to auto80 For This Useful Post:
    karolp1993 (30th October, 2016)
    Feb 2016
    Quote Originally Posted by auto80 View Post
    Cheers
    Thank s for the information
    I have attached the lib file as well
    Jul 2014
    I mean srs modules files for clear
    Feb 2016
    what is that .. i got only the device (which is clone i guess ) and carproc V9.31 application./..
    so please tell me what do i need to do.. to reset mentioned Airbag modules....
    (step to do that please )
    thanks a lot friend
    Aug 2008
    first step is dont use software version 9.31 with that clone carprog has its hardware for v4.01 software only
    second step is read all threads to do with carprog and check yours to see what repairs it needs doing to it
    third step is to update to 4.74 firmware so you can use 4.74 software or buy fw from somewhere and update to 8.21
    only other option you have is to buy a new carprog (version 8.21)
    Feb 2016
    Quote Originally Posted by tango View Post
    Thanks for the steps
    1.I have Downloaded v4.01 software and connected with the device.
    and as you mentioned in as a second step .. i downloaded the 4.74...
    so it contains
    201213CAR000ME61.lib
    CarProg-5.31.exe
    so what do i need to do ... just run that files or anythin else
    Thank you
    Aug 2008
    No you need to jtag the 4.74 fw to carprog then you can use higher software than 4.01
    also look at what repairs your carprog needs
    There's carprog threads all over the forum showing what's needed etc
  10. #9
    Feb 2016
    No you need to Ktag the 4.74 fw to carprog then you can use higher software than 4.01
    Thank for the reply
    my knowledge of carprog is bit low... can i know do i need to do any changes in my Carprog or can i use my carprog without doing any modifications.
    im really sorry if im asking a stupid questions .
  11. #10
    repairmymodule's Avatar
    Aug 2014
    USA, Earth, Milky Way Galaxy, Universe, Unknown
    You can use your carprog to read eeprom without any modification. Use software 4.01. Select EEPROM from the left menu, once it loads, click the settings (wrench icon) in upper left corner and select eeprom series you want to read.
    If you are getting a lib file error, just make sure there is the correct lib file in the directory of carprog.exe file. Lib file should match your devise serial number
    However, the 52J30 toyota module you need to read renesas 1725 processor. Not even full original carprog tool can read these. You need a programmer such as ETL, Carprotool or SMOK to read these
  12. #11
    Aug 2008
    just corrected my post because for some stupid reason my phone changed jtag to ktag
    to put any new firmware on the carprog you need a jtag device to do it most use jlink or wriggler
    all info for doing this is on the forum
  13. The Following User Says Thank You to tango For This Useful Post:
    repairmymodule (25th September, 2016)
  14. #12
    Feb 2016
    Quote Originally Posted by repairmymodule View Post
    Thanks for the information
    that means i can reset 89170-B2C60 module
  15. #13
    Aug 2014
    I do not know what chip is in that module. If it is an eeprom yes. If it is a Renesas mcu, then no
  16. #14
    Feb 2016
    below the picture of that unit..
  17. #15
    Feb 2016
    Please check the attached chip as well
