Das Xentry with AVDI interface
    ruffles1986's Avatar
    Sep 2011
    In the Garage
    Default Das Xentry with AVDI interface
    Is possible run das xengry throug Avdi interface? Avdi is original but not das xentry. I instal passthru drivrs for das(avdi drivers) but i get error in slave. ini file. Message said check write protect, i check it and bave notactive protection...
    If any can help i apreciage it. Thanks
    V.I.P. Master of the IMMO
    lupu_sandu's Avatar
    In my immobox...
    I use 09/2010 DAS with AVDI as passthru device and working great.
  3. The Following User Says Thank You to lupu_sandu For This Useful Post:
    ruffles1986 (29th September, 2016)
    Aug 2013
    Is it possible to use AVDI with DAS offline?
    If so, I would appreciate the steps! Thanks Sir!
    Nov 2014
    Germany
    Same probleme. Please, help. Thanks
    Quote Originally Posted by ruffles1986 View Post
    Rito's Avatar
    To use Xentry whith AVDI is need virtual machine ?
    einet's Avatar
    to use xentry need a DELL630 or the IBM Laptop
    or use VM with Dell image
