Results 1 to 4 of 4
    GODS COUNTRY
    Default Best image and skin for Zgemma 2s.
    Hi I was using MTPockets openatv image on my Zgemma but yesterday it got stuck on 'boot' when starting up so needed to re-flash my box, MTPockets is no longer available to use so flashed with Sucmnsee's Vix image however I don't like the skin it has so tried to change it but again on start up it stuck on 'boot' so had to flash again.
    What would you say was the best image to use and where can I find it?
    Also what would you say was the best skin?
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Try my old 2s backup image;
    http://www.digital-kaos.co.uk/forums...proved-ky-Skin
    Comes with kiddac's original sky skin, you will have to update the image once installed as its a bit dated now but still works.
    If you don't like it then try whoosh's build but you'll have to google it as linking to other like forums is against forum rules.
  3. The Following User Says Thank You to martin035 For This Useful Post:
    blacky1973 (27th September, 2016)
    GODS COUNTRY
    Cheers mate, I went with Whoosh's build, seems OK so far but don't like the skin so tried to change it to MTPockets BluedHD but again on startup it freezes on boot so had to re-flash.
    Guess I'll just have to stick with it.
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Blacky1973, if you don't like the skin thats on whoosh's or my image then install another skin via the plugin skin downloads or .ipk file ie chab's excellent skyQ skin, as it sounds like the blueHD skin you've installed has a bit of bad coding in it which is causing the boot issues.
  6. The Following User Says Thank You to martin035 For This Useful Post:
    blacky1973 (28th September, 2016)
