azepakoI have a very similar radio, PCB looks just about the same can you help please?
Renault 281151185R
Renault 281151185R
I see that the radio isn't mounted to a car. It cannot work without being mounted to a car because it has CAN-H and CAN-L pins.
I read on other thread that a guy pressed the setup and return buttons and the message displayed on the screen changed to "seed: ......" (some numbers). Maybe this can help, maybe someone know how to find the key using that seed number.
please help me
<<<<----- THANKS BUTTON
i have martech box3
I have same problem and I can’t find the solution!
i have martech box3
The original radio is stolen and the connectors are cut from harnes. The owner of the car bring me a radio and connectors from junkyard.
My opinion is the problem the VIN in the radio is not same with the car’s VIN.
I dont know how I can change the VIN in the radio...
I have tried with original Abritus and I can’t change the VIN in the radio.
If I help you don't forget press the THANKS and REPUTATION buttons
I have the same problem with this unit Visteon, from Duster 2019
Part code: 281158515R
Part Name: R013-X07
Any solution ?
Thanks and best regards.
Meat-Head (20th February, 2024)
I made diagnositc in car and I see the radio not have the same VIN like car and for this reason show Locked in display !
I try to change VIN in radio by OBD with AVDI online and not let me to do it.
I find in bottom side of unit also some pads TX, RX and XCLK I think this can be a solution for change or update VIN in MCU, know some one solution to chenge VIN in this unit radio ?
Thanks.
Meat-Head (3rd March, 2024)
