Results 1 to 5 of 5
    Sep 2016
    Default Need help identifying ECU components from a Ford Fiesta 2003 1.3 Petrol.
    I have a broken ECU (2S6A 12A650 PD) in my car that was caused by the ignition coils. The Ignition transistor (BTS 2140-1B) seems to be burnt, but there seem to be four components that look like resistors that are also burnt. Some of them are so badly burnt that I cant identify their color code.
    So I ask, does anyone here know what those components are, and their value?
    I have attached two images, one of them shows the burnt components with the transistor on the left and the unknown components on the right.
    fakturnii's Avatar
    Mar 2016
  3. The Following 2 Users Say Thank You to fakturnii For This Useful Post:
    Meat-Head (17th November, 2017), opeturs (27th September, 2016)
    Sep 2016
    Thank you! So those are in fact resistors.
    Jul 2016
    BTS2140-1B Ignition Driver IC, approximately 1USD
    May 2011
    Hi Friends.
    Did You identify value of those 4 resistors?
    Something else was bad in Your sim21?
    Best regards!
    EDIT:
    I think that's 0.22ohm resistors, but can I solder resistor other than MELF?
