Xorion boot logo maker.
Results 1 to 2 of 2
    GODS COUNTRY
    Default Xorion boot logo maker.
    Wanting to change my bootlogo on my Zgemma,
    I'm using Whooshbuild,
    I've made my own picture I want to use,
    I start up Xorion bootlogo maker,
    Select the image I wish to use as my new bootlogo,
    Convert it to .MVI
    input my devices IP, root as username and password,
    send to my device,
    It says it was successful,
    But upon rebooting the original bootlogo is there not the one I chose,
    FTP'd into my box and the .MVI files i chose are there under usr/share,
    Any suggestions please?
    Last edited by blacky1973; 28th September, 2016 at 01:35 PM. Reason: Extra information
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    From Whoosh's Q&A's
    Q41. How do I use my own bootscreens
    1. The newer builds use a plugin to swap the boot screens around and no matter what normal action you take it won?t make any difference except maybe adding your screen to the 8 that are already there.
      To remove the plugin delete the folder called: BootLogoSwapper from within the usr/lib/enigma2/python/plugins/extensions folder.
      Use whatever method you are happy with. Once you have deleted it it has gone.
    So, looks like you need to get shot of that plugin, then install your bootlogos via Xorion
  3. The Following User Says Thank You to martin035 For This Useful Post:
    blacky1973 (28th September, 2016)
