Page 44 of 135 FirstFirst ... 3439404142434445464748495494 ... LastLast
Results 646 to 660 of 2022
  1. #646
    Feb 2018
    Default exit from ddegraded mode AUDI Q5
    hi
    Power loss and degraded mode
    audi Q5 03L906022ER
    dtc
    calculateur: 03L 906 022 ER Mat: 03L 906 022 B
    version: R4 2,0L EDC H01 4390
    4875 - Pompe 2 de liquide de refroidissement
    P261A 00 [039] - Coupure
    5380 - Soupape de volet de dérivation du filtre à air (N275) Rupture
    P1016 00 [039] - -
    4892 - Soupape de recyclage des gaz (N18) Dysfonctionnement
    P0403 00 [167] - -
  2. #647
    Spain
    i need remove DPF and EGR for Opel Zafira B 1.7 CDTI 110hp year 2010.
    tell me if i have to disconnect any sensor?
  3. #648
    Mar 2018
    Slovakia
    Default DPF off
    PLS I need remove DPF.
    BIG THX
  4. #649
    huskypt's Avatar
    Apr 2016
    PT
    Quote Originally Posted by sf777 View Post
    BIG THX
    There is your mod .... No chks
    Pass by PM
  5. The Following User Says Thank You to huskypt For This Useful Post:
    sf777 (26th April, 2018)
  6. #650
    huskypt's Avatar
    Apr 2016
    PT
    Quote Originally Posted by kamandulillas View Post
    There is your file mod.... pass by PM
  7. #651
    Apr 2017
    HI, can you please EGR OFF?
    it?s edc16c35
  8. #652
    Nov 2017
    can somebody make egr and dpf off please
    passat CBDC
    110HP
    Bosch EDC17CP20
  9. #653
    Mar 2018
    Slovakia
    Quote Originally Posted by huskypt View Post
    Pass by PM
    pls send me pass for file " WinOLS_(Original)_-_SN100L8000000_DPF OFF).rar"
    thx
  10. #654
    Jul 2013
    Latvia
    Quote Originally Posted by Andytech3 View Post
    it?s edc16c35
    Hi! Here You are.
  11. The Following User Says Thank You to flashtech For This Useful Post:
    Andytech3 (27th April, 2018)
  12. #655
    sebasapri's Avatar
    Apr 2015
    Balcarce
    Hello everyone.
    Any of you could help me with the DTCs.
    I need to turn OFF the DTCs that work with the O2 lambda, we have removed them and their catalysts. I do not know which is the right one i dont have officila BMW scanner,i could only see the DTC with the Delphi i attached the pic too.
    Thanks for your time.
    DTC CODE LIST E46
    http://forum.e46fanatics.com/showthread.php?t=303141
  13. #656
    Apr 2018
    MD, USA
    Hi, can you send me damos to open this EDC17CP09 ( BMW X5 35D USA version)? I want to turn off the EGR, DPF and SCR but it will be step by step and I want to learn in the process. Im using Winols 2.4 and I don't have the right damosThank you
  14. #657
    Hi my friend
    need SCR and DTC off please
    Thanks!
  15. #658
    Spain
    Default Paasta Remove dtcs PPD1.1
    Passat Dtc ppd1.1
    i need remove P1262 P1267
    MIL ON in dash.
  16. #659
    Oct 2016
    Hello
    I need air mass removed edc15c2
  17. #660
    Apr 2018
    Default EGR OFF Megane 2
    HI,
    Can you please EGR OFF ? Megane2 SID301
    Thanks in advance
