Page 102 of 136 FirstFirst ... 25292979899100101102103104105106107112 ... LastLast
Results 1,516 to 1,530 of 2035
  1. #1516
    Yhoni's Avatar
    Jun 2014
    Somewhere in time...
    Quote Originally Posted by kive View Post
    here is the original one
    Hello friend, here is your file egr-off and maf-off.
    Click "THANKS" AND "REPUTATION" button and then i will send your password.
    Greetings.
    If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
    I do not answer in private questions that can be solved in public.
  2. The Following 2 Users Say Thank You to Yhoni For This Useful Post:
    gloric (5th October, 2021), kive (4th October, 2021)
  3. #1517
    Default scudo
    hi, need help with fiat scudo sid803a hw9661642180 sw9664626680 need dpf off and cs. thanks in advance
  4. #1518
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by voodevil View Post
    Hello friend, here is your file.
    Greetings.
    PS: I don't have the checksum verification tool, sorry.
  5. The Following User Says Thank You to Yhoni For This Useful Post:
    voodevil (5th October, 2021)
  6. #1519
    Quote Originally Posted by Yhoni View Post
    Greetings.
    Thanks, and i need to disable dpf in bsi ? Reset dpf counter in ecu?
  7. #1520
    Yhoni's Avatar
    Jun 2014
    You should Reset dpf counter in ecu before to write DPF OFF file.
  8. #1521
    Default Mazda 3 dpf + additive tank off
    Can you help me with EDC16c3 mazda?
    Ecu 0281012531
    Thanks!
  9. #1522
    kosta89's Avatar
    May 2018
    Georgia
    sonata 2014 hybrid 2.4
    Continental 2g911 sim2k 143
    YCY4RC1A
    VIN KMHEC4A42CA031248
    NEED DTS OFF P0420
    tnx for help
  10. #1523
    Apr 2021
    Greetings.
    Hi, the maf delete worked, thanks for that.
    But now the idling is very bad and sometimes the engine dies. I Tried to increase the idling RPM a bit, still the Same problem. Is there maybe a Issue in your file or a smart workaround?
    Switched back to the original File and no issues.
    Measuring Block 1 says 5,xx mg of fuel while idling (original, stable)
    With your Custom file it changes Between 0,4mg ang 6,xxmg of fuel (unstable)
    I hope you can help me.
  11. #1524
    Yhoni's Avatar
    Jun 2014
    I would try to disconnect the lambda probe to test if the idle is maintained.
  12. #1525
    Aug 2016
    Bloemfontein South Africa
    Default Help please with Ford Transit
    Good afternoon, can anybody please help with EGR off on a Ford Transit with SID802?
    Thank you
  13. #1526
    Apr 2021
    The Car doesnt have a Lambda Probe (golf mk4 asz)
  14. #1527
    Yhoni's Avatar
    Jun 2014
    Ok, so you should write the original file, disconnect the maf and check if the idle is stable or if the engine stops as well.
  15. #1528
    Yhoni's Avatar
    Jun 2014
    Quote Originally Posted by dEONBE View Post
    Thank you
    Greetings.
  16. The Following User Says Thank You to Yhoni For This Useful Post:
    dEONBE (6th October, 2021)
  17. #1529
    Apr 2021
    I tried that already. With disconnected maf the idle is ok, just no power
    I also tried your file with maf pluged/unplugged.
  18. #1530
    Yhoni's Avatar
    Jun 2014
    Ok friend, I will review it tomorrow and inform you.
    Greetings.
  19. The Following User Says Thank You to Yhoni For This Useful Post:
    kive (7th October, 2021)
