kive (7th October, 2021)
If my post has helped you, do not forget to click on the "THANKS" and "REPUTATION" button !!!
I do not answer in private questions that can be solved in public.
kive (7th October, 2021), Lusitano94 (7th October, 2021)
Please dear members push the button thanks and reputation button(stars)
do you need help? fill it in !!!
Model:
Motor capacity:
Diesel/Gasoline:
Production year:
ECU type and number:
Memories :
https://www.digital-kaos.co.uk/forum...63#post1660863
Exactly.
After that i Tool a look into the Files.
The 3 data zones just Contains maps for Automatic, 4wd and manual. On the second file you edited the maps for 4wd, which does Not effect my car, which is a manual und you already edited the fwd maps
Tomorrow i will try to reset the Adaption Values for idle with a bosch tester. Maybe that helps
hi i need egr off this ecu
i try egr remover 2017 but not work.
thanks.
HW: 3031323052
SW: 3039343752
smtmrc (9th October, 2021)
Hi, I need DPF-OFF for this file from Opel Insignia 2010 with edc17c19 ecu
ADS DPF Remover no work well
Thanks a lot
Can anyone help to turn off DPF and EGR for this ECU?
VOLVO V70 BOSCH 0 281 012 765 EDC16C31
MPC564; flash: M58BW016DB
Thank You
