Please assist I have a 2007 mini R50
Bosch MED17.2 CAN
HW 0261201966
HW Ver. 07584954
SW 1037391678
Ext Flash
Please remove DTC P2A8B & P2B15
Thank you
Bosch MED17.2 CAN
HW 0261201966
HW Ver. 07584954
SW 1037391678
Ext Flash
Thank you
Hi, Can you do for me EGR off? I need complete file ready to write. Thanks.
ProblemChild (31st March, 2024)
Hi, plase for working solution for nox and egr off. Car is golf 5 1.4 fsi (med 9.5.10).
Hello all
I have a problem with the DTC in the VOLVO V70 2.4 petrol 170 PS
ECM-xxxx is a mistake used by Volvo:
ECM-2200:
P0137
P0138
P0141
P0143
P0144
ECM-250A:
P0171
P0172
The motor controller is DENSO HN-2.
The Annex is set read by the IO terminal memory. It is a full flash reading areas as would be read by BDM. Reading the driver did on the table.
If anyone knows the drivers DENSO enough to remove these errors I'd be very grateful.
Press the button if my post was helpful.
Hi, I need egr off simos PCR2.1 Seat Ibiza 1.6TDI
pleace off egr edc15c3 master
Malaszek1995
https://gofile.io/d/AUVKnR
grzesdtp
https://gofile.io/d/ogmsMB
Mario1004
https://gofile.io/d/thXzyQ
Meco
https://gofile.io/d/69ugIP
All files are without checksums.
Possible to Delette DPF EGR MB 200
EDC16C32
BusCan (1st April, 2024)
Hello friends please help mee i need SCR OFF ecu golf7 2014 bosch 0281031308 edc17c64
Thank you a lot
I'm not using any kind of cracked software, until now i never had issues with a bricked ecu caused by a tuning or additional option and i do a lot of vehicles.
I was just saying that because sometimes the engine management light stays on or a pcode is still active so i could give support.
007bader - You can download your file in attachment.
EDIT: Is anyone else really helping out all of these members? I mean i want to help out but it's a lot of files to process.
greeting
I need adblue off (SCR off) ford ranger 2.2 2017 and write me if I should disconnect the jack from the adblue tank or leave it plugged in, it says on the board Adblue service required for engine start but i can't start
