pablos1234 (5th July, 2017)
New file, disconnect egr;
WinOLS (Ford Kuga (Version 1) - FR1D0B0000000).rar
Hello!! Thank you very much for your file, draganelektricar
I have tried but the problem still there.
it's possible to delete this DTC P1401 and P1403 please?
In this link there is ORI file, EGR Off and picture with errors
https://mega.nz/#F!mssBHBhS!FWAkbGEFTsB2a_tBv0-3bw
thanks in advance
A6 EDC16C3X PLEASE REMOVE EGR. I RAD WITH FGNTECH ON OBD
Hello, is it possible to have
dpf + egr off on this qashqai ?
thanks in advance...
qashqai sid303.zip
Guys all hello. There is a problem tricky. Need specialists. Auto. Mercedes
G300TD 1996g unit Bosch 0 281 001 880, Mers A 025 545 55 32 on the block
written MSA25.1 or bosh number EDC1.4 (MSA 15.1-3-13) inside 2 flash drives.
Question, Disable EGR and add power. Or deactivate the error code - error
P1404 Exhaust-gas recircul. Ctrl. Circuit Control Unit error. All read,
inside 2 M27C2001
Thank you in advance.
VAG Bosch ME 7.5.10
its posible turn off DTC:
P0401 - 16785
P1388 - 17796
P0328 - 16712
P0139 - 16523
Cars run normal but MIL ON.
Try and report
03G906016GC (Audi A6 (EGR OFF)) EDC16C31.zip
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
hello can you remove the ? egr in sid201 for peugeot 407
i make 2 file with jtag 1 complete and 1 separate thanks
Hi please help me to remove EGR (DTC P2511). Mercedes W203, C200 CDI, 2005, I TRY WITH VOLTA DON'T WORK !!!!
ECU BOSCH EDC16C2 0281012342 A6461501491
THANK'S
peugeot 307 cc greetz 307FULL.rar
2009 Mercedes Atego 290HP. How to read ECU for SCR off?
UNI
HY
Help
3.0 V6 mercedes edc16
I cut DPF , there is no fault ,car will not go
Where did I ruin it?
flesh.rarflesh.rarFLESH_DPF_off.rar
hello i am trying to disable flaps off but not succesfully please can someone help to disable intake inlet port shutoff and dtc error code p1189 t5hanks
