Page 30 of 135 FirstFirst ... 2025262728293031323334354080130 ... LastLast
Results 436 to 450 of 2022
  1. #436
    Senior Member Novik_UA's Avatar
    Thank, but is avaible solution for this ECU without limp mode torque limitter touched ?
  2. #437
    Feb 2017
    HI, can you please EGR OFF?
    edc16c34
    Ford fiesta 1,6 66kw TDCI 2006year
    ford maps.rar
  3. #438
    Jan 2016
    Default Ford Focus 1.6TDCI 2009
    Hi!
    please, may you help me with DPF/|FAP OFF as DTC code P2458,P2453,P242F or additive module removed?
    Car data are:
    ECU Bosch EDC16C34
    Thank you in advance!
  4. #439
    Apr 2012
    minsk
    Default vw polo 1.4 tdi edc17u05 DPFOFF EGROFF DTCOFF 2002
    hi, help please me with dpfoff and egroff with ecu edc17u05 vw polo 1.4 tdi with DTCoff (now i have error p2002) thanks
  5. #440
    Europe
    DPF OFF
    pass pm
  6. The Following User Says Thank You to Yura123 For This Useful Post:
    Romaus (28th August, 2017)
  7. #441
    Mar 2009
    Europe
    Default Ducato 2011_0281016050_1037501107 EDC16C39 DPF off
    Can any make good DPF off..I try with two file,any not have error,car drive ok and problem throttle not go in sleep mode and batery empty for 3-4 hour...other file with dpf remover car in limp mode and P1250 not erase.
    0281016050
    1037501107
    23 02 2011
    EDC16C39
  8. #442
    spiridonas's Avatar
    Hi, i need to DPF/EGR off in citroen jumpy ecu dcm3.5
    Please only tested solution.
    Many thanks in advance
  9. #443
    May 2017
    City 17
    Please EGR off this FORD FOCUS MK3 2.0 TDCI DCM3.5 ecu
  10. #444
    Portugal
    I have a Seat Ibiza 1.4 tdi of 2006. They made a change in the car and took out the turbocharger and put a turbo of variable geometry. Can someone change the ECU map so I can work with this turbo without making a mistake and remove EGR? Original map in atach. Thanks in advance.
  11. #445
    Portugal
    No one can help?
  12. #446
    Sep 2011
    Bulgaria
    Seat Ibiza 1.4 tdi
    4C110
    6C110
    56166
    76166 EGR
    56FA8
    76FA8 N75
  13. #447
    Portugal
    HI
    Can you please delete DTC error P0420/16904 for a VW Polo 1.2 12V with ECU Siemens SIMOS 3PE. Thank's in advance.
    JB
  14. #448
    johak's Avatar
    Quote Originally Posted by JotaB View Post
    HI
    JB
    try this...
  15. #449
    Portugal
    Hi mate
    Can not open it. It's damage or unknown format. Can you upload again please.
    Tanks
    Quote Originally Posted by johak View Post
    try this...
  16. #450
    johak's Avatar
    is not damaged
    try the latest version of winrar
