HI
please help for dpf off or dpf egr off files best 2 files for opel zafira b 2006 z19dt edc16c9
HI
Can you please turn off egr on this map, 09 VW Touran 2.0 TDI PD BKD 140 no DPF EDC16 u34, I have fitted a egr blanking plate and need to sort out the map,I have tried it myself but this is beyond my skill level.
Thanks in advance!
Hi, please help me with DPF, EGR, TVA - off on Iveco Daily EDC16c39 3.0 HPI
hi
test end raport
ferreirajcsf (15th April, 2018)
Thanks diagun, that was fast!
will try it and let you know.
edit: tried it but p0401 still comes up
pass for 1 files
p0401 off test raport
sum no ok -sory
2 files sum ok
thanks again diagun, what's the difference between the 2 files? just the dtc off?
Will test tomorrow and let you known.
- WinOLS p0401off sum ok- 389855).rar sum ok
Can You help is DTS off in MED17 of Ford http://www.digital-kaos.co.uk/forums...7-need-DTS-off ?
I can make EGR and DPF off VANOVANOS
Tried the one with the checksum ok, the fault still there!
thanks for trying diagun, maybe someone else wants to have a look at it.
Address 01: Engine Labels: 03G-906-016-BKD.LBL
Control Module Part Number: 03G 906 021 MP HW: 03G 906 021 AN
Component and/or Version: R4 2,0L EDC G000SG 1322
Software Coding: 0000072
Work Shop Code: WSC 01324 020 00200
VCID: 79F9BC0830A4C4F61A-802C
1 Fault Found:
001025 - EGR System
P0401 - 000 - Insufficient Flow
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 102195 km
Time Indication: 0
Date: 2000.00.00
Time: 19:23:24
Freeze Frame:
RPM: 1533 /min
Speed: 0.0 km/h
Load: 20.0 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 370.0 mg/str
Mass Air / Rev.: 590.0 mg/str
Maybe try this let my know if it works i hope it will work
I have made 2 file try both
if not work disconect egr
and send me the faultcode
1 Fault Found:
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 102195 km
Time Indication: 0
Date: 2000.00.00
Time: 19:23:24
Freeze Frame:
RPM: 1533 /min
Speed: 0.0 km/h
Load: 20.0 %
Duty Cycle: 14.6 %
Duty Cycle: 100.2 %
Mass Air / Rev.: 590.0 mg/str[/QUOTE]
ferreirajcsf (17th April, 2018)
jelmer52, help me, please, with dpf-egr-off. I will try to repair tva
Thanks jelmer52, tried both but same problem, p0401 comes up strait away
I can disconnect the egr but dont think it will make a diference, I have fitted a blanking plate
I'll do it tomorrow to see if I get any other fault codes
edit: I have sorted it, I have done a map with volta and it seems to have worked, the egr duty cycle is now a constant 95.5% and the fault code hasn't come back, I'll drive it a few more days and keep an eye on it.
Once again thank you jelmer52 and diagun for your help!
