MagicMotorsport FLEX, Kess / K-Tag original, PCM Flash, MMC Flasher, BitBox, 2wd Dynomet Dyno Road, Ori WinOls.
We offer: Cars, Trucks, Agro, Construction Machines Tuning / DPF / EGR / Flaps / Throttle / Ad Blue / Lambda / DTC, IMMO off. Also EDC17 IMMO off BY EEPROM with no faults on a dash!
furnata (10th October, 2016)
need to dissconect sensors ???
Im here to help and to be helped
Please DPF off peugeot 307 1.6hdiBOSCH EDC16c34 org.rar
hello please dpf off bmw edc17cp02/06
hi
please need dpf + egr off on this psa 307 hdi edc15
Check this one and report,cs done
Please dear members push the button if my work was helpfull!
And reputation button(star)
moky (10th October, 2016)
Hello. I search solution for DPF and tested EGR please. I test a lot of file. dpf not good because after 400 KMS and preheating lamp flashes. ASTRA H 1.7 CDTI 2008 denso ECU SH7058.
io-terminal DENSO.
Thank you in advance.
Hi!
I'm looking for DPF and EGR off on my car, as I'm going to clear my DPF this week.
megs.rar
Thanks for the help!
Honda Accord 2.2 150hp edc17cp06
Thanks!
Hello, i need fap off.
ECU info:
HW - 0 281 011 558;
SW - 1037374181;
ECU have several FAP errors:
P1434 - additive pump open circuit;
P1446 - lewel in additive tank is low;
P1457 - particle emission filter holed
P0470 - exhaust pressure sensor malfunction;
Hello !
Fiat Ducato 2.3JTD need EGR_OFF
0281014209 EDC16C39
Thanks in advance !
'" live and learn........ if you wont ....you ain't "
_______ . ____ . __ . __ . _______ . __ __ __ ... ---
If my post was HELPFUL please push THANKS button
Hi there,
I have done Runner Flap Delete on my VW Scirocco R MED9.1......Are you able to disable it from the file so I don't get error please?
HW: 0261S02736
SW: 1037510588
UPG: 1K8907115D 0030
1K8907115D 0030 - Original.zip
Hi need help to remove dpf for mazda 6 2.0D 2006
HW: RFY818881
SW: SW-RF7JEU000.HEX
jires11 (19th October, 2023)
