Hello!
Needed EGR Off (EGR faults Off) please...
Audi A6, 2.0L, BLB
EDC16U31
03G906016BF
0281011850
382716
03G906016BF_BDM.ZIP
Solved!
I learned how to...
cerato 1.5 dizel bosch 0 281 011 878
39107-2A110 DA06
39101-2A110
99ULMI03
AM29F400BT
75vG.
028101187810
18781037372693B2
93B2
65WFSS01V70_02B265_V
DTC CODE = P0403 P1112
EGR OF PLEASE THANKS
ORJ.rar
Hello!
Audi A6, 2.0L, BLB
EDC16U31
03G906016BF
0281011850
382716
03G906016BF_BDM.ZIP
Solved!
I learned how to...
Can you make these EGR off with all related DTC?
File in attachement:
flashbckp.rar
Thanks!
hi, can you help me with dpf and egr on an Audi A3 170cv ppd 1.2? many thanks in advice for your kindly
hi, can you help me with egr off peugeot 307 hdi 1.6 80 kw
edc16c34 bosch 0281011634.Thanks
Citroen C4 EGR off pls
cirtoenC4AHMET USTA1.rar
Hi.
Can help with dpf off and dtc DF 308 on ecu edc16 suzuki vitara
HI !i need EGR OFF from FORD TRANSIT
Can you help me with EGR off on peaugeot 307 1,6 hdi BCI 0281011863 EDC 16C34
pezo 307 16c34.zip
[Quote = netko; 2889875] Hola
?Me puede ayudar con EGR apagado en peaugeot 307 1,6 hdi BCI 0281011863 EDC 16C34
pezo 307 16c34.zip[/ quote]
test and report
pezo 307 16c34 egr off.rar
nissan interstar 2500_edc16c36.zip
Help plase fap off and dtc delete!!
Nissan interstar 2.5 edc16c36 same engine and ecu as renault master 2.5.
ecu: 281 013 363
1039S14507
Dtc:
P2A00
P0571
P2002
P2299
P0089
P0180
P2A00
P0571
Thanks!!!
Hello Please , I need FAP off and P2002 dtc off from Audi A3 170 cv BMN ECU PPd 1.2 , I tried with swiftec but dislplay is still showing message so car run for some km later get emergency mode,,
regards thanks in advance
here Ori flash BDMOri.rar
need help dpf off Simos ppd 1.2 golf
Hello, I have problem removing throttle and EGR on Astra H 1,7CDTI EDC16C9, kan you help me with tested solution, everything tested so far not good, the best solution is with no DTC and no limp mode but there is no turbo...
here is link to my dump: http://www.digital-kaos.co.uk/forums...=1#post2894570
HI,
I need DPF off Mercedes C220CDi 2008
Ori.rar
