E.C.U PROBLEMS PASSAT 2.0T TSI - 2010
Results 1 to 5 of 5
    Sep 2016
    Default E.C.U PROBLEMS PASSAT 2.0T TSI - 2010
    Friends Help,
    I need to upgrade the software of my E.C.U the PASSAT 2.0T TSI - 2010. Need Original File.
    The car does not work after warm!
    I changed the original VW parts such as nozzles, coils, rotation sensors, water temperature, MAF, Phase, engine timing.
    It works well for about 30 minutes and then freaks out its operation, swaying and with the light injection, turns on and off with the error codes 000768 and 000801.
    Follow the car information.
    MED17.5: Banghead:
    0261S05157
    1039S40501
    06J906025DC
    Motor CCTA 6997
    WVWLV83C6AE175540
    Please anyone who can help,
    Thank you,
    you need a new ecu
    Sep 2016
    [QUOTE = Alpinesport; 2860292] r?pido Voc? Precisa de nova ECU [/ QUOTE]
    Alpinesport, thank you for returning.
    More within all the parts that have been replaced, I understand that with the E.C.U software changes it will return to its originality. So I have to try to return to the original factory information.
    So I decided to use the forum to ask for help.
    Sep 2016
    portugal
    He already changed the sensors the remap not solve the problem better exchange ecu
    Sep 2016
    Juanes
    Thank you for your feedback!
    I did not understand your answer, could you give more details!
    For we are finding is that the module, there seen have gone twice for a simulator test and all parameter settings are normal.
    For the car starts to swing all parameters after heat about 30 minutes, when the processor is in all its operating fullness.
    So the idea to re-record the car's software, if this is possible?
    Thank you
