Page 16 of 35 FirstFirst ... 6111213141516171819202126 ... LastLast
Results 226 to 240 of 521
  1. #226
    Jan 2017
    Quote Originally Posted by Yuki Shi View Post
    Hello, what's the version of X100 pro device? Is it the latest?
    to day my friend tried it wite x100 pro new opdate fail 3 times
  2. #227
    Aug 2015
    BEHIND YOU
    Quote Originally Posted by elmelor View Post
    Hello colleagues.
    New settings:
    Jac j5 (Chinese car) needs pin-programming ok
    Mg350, mg3, mg5 (Chinese auto) need pin-programming ok
    Jeep Cherokee and Dodge Durango 2014 - Proximity - needs pin -programming ok
    Jeep wrangler 2015 - reads pin, program well control and key.
    Chevrolet cruze, Orlando - 2012-2014-> read pin ok- program keys and control ok
    Chevrolet spark gt 2015 programming well, needs special chip or original key.
    Chevrolet sail 2014- id48 program key ok
    Nissan np300 program key and control ok, need original key
    Unscheduled
    Subaru xv 2012-
    I recently purchased RFID adapter
    When I have results I will share them
    Greetings colleagues
    did you tried the subaru xv? or not yet?
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  3. #228
    Apr 2017
    Quote Originally Posted by akwasi View Post
    update failed? what did the device show on screen?
  4. #229
    May 2011
    hi
    why this tool is always failed on dodge chrysler vehicle always display message "security verification failed try after 2 min. " and after 2 min same message agian....now i have dodge magnum i have skim code but car wont crank....and there are 4 number of key in the memory..what to do...????? how to make the car start where should be the problem....waiting for reply
  5. #230
    Apr 2014
    Add key on Yaris 2014 NCP150 succes full, jobs done on 2 minutes,
  6. The Following User Says Thank You to sadarmeng For This Useful Post:
    p1et (19th September, 2017)
  7. #231
    Aug 2015
    BEHIND YOU
    mitsubishi outlander 2010 usa program ok 1 minute .. it was smart key
  8. The Following User Says Thank You to eliaselias For This Useful Post:
  9. #232
    Apr 2017
    hope it helps
  10. #233
    Apr 2017
    Quote Originally Posted by digimile View Post
    hi
    Hello, pls turn on the ignition switch and wait for while, to see if the car can start itself.
    And which year did your car produced?
  11. #234
    Nov 2014
    Hello colleagues.
    New settings:
    Unscheduled
    Subaru xv 2012-
    I could not program it, I ended up doing the work with tm100. If anyone can or could do it, I would be grateful if you would share your experience
  12. #235
    jodge's Avatar
    Mar 2017
    Renault Clio 3
    2006
    Add new key working with all key lost option
    Pin code is necesarry!
    Pin code reading failed, done with another tool
  13. #236
    Apr 2016
    x300pro
    nissan navara 2008
    add key (remote 2b pcf7946)
    read pin code ok very fast
    programm key error lost comunication
    add key fvdi 2015 ok
  14. #237
    Aug 2015
    BEHIND YOU
    Mitsubishi outlander 2011 es sport program smart key ok
  15. #238
    Samsara's Avatar
    Quote Originally Posted by eliaselias View Post
    Hello.
    Can you tell me which transponder in this key ?
  16. #239
    Oct 2012
    Bucharest
    Pcf 7936 precoded always biphase transponder mode configuration
  17. The Following User Says Thank You to mradu2005 For This Useful Post:
    p1et (4th October, 2017)
  18. #240
    Oct 2012
    Bucharest
    Quote Originally Posted by Samsara View Post
    Hello.
    Pcf7936 prcoded biphase always transponder mode configuration
