Page 22 of 35 FirstFirst ... 12171819202122232425262732 ... LastLast
Results 316 to 330 of 521
  1. #316
    Apr 2017
    Quote Originally Posted by dimitar View Post
    Fvdi 100$
    Carprog 40$
    KKL cable 5$
    Opcom 15$
    PSA Lexia 40$
    ...........etc...etc.....
    X100pro 319$ + shipping + tax
    X100pro will never match the functions of the above mentioned tools EVER
    Worst spent money ever...
    one device can not do every models
  2. #317
    dimitar's Avatar
    Quote Originally Posted by Yuki Shi View Post
    Yea but at least one device SHOULD do what the company that sells it claims can do
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  3. #318
    Feb 2014
    Even top tool like AVDI doesn't do what it claims. What do you expect from X100?
  4. #319
    Faraday's Avatar
    May 2012
    The dark side of the moon
    Elm327 + forscan working 100%
    You say that forscan bypass FDRS?
  5. #320
    HeXeN's Avatar
    Mar 2015
    Have you done 100% ford proximity with forscan?
    Elm+what to do mazda proximity?
  6. #321
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by HeXeN View Post
    Proximity? Are you kidding? The forscan unable to program a simple 8C spare key to BT50
  7. #322
    May 2015
    2012 Honda Civic US add key ok
    Sent from my SM-G950U using Tapatalk
  8. The Following 2 Users Say Thank You to Nymike For This Useful Post:
    Faraday (19th December, 2017), maybach_ (19th December, 2017)
  9. #323
    Nov 2014
    opel astra j 2012, all the lost keys ok (I need pin), key produced with kd900, ok
  10. The Following User Says Thank You to elmelor For This Useful Post:
  11. #324
    Senior Member maybach_'s Avatar
    EU
    Opel Mokka 2015 all key lost via Insignia meny 15 min, no need program remote separately
    Need pin for this jobb
    Be allways Thankfull!
  12. The Following 5 Users Say Thank You to maybach_ For This Useful Post:
    elmelor (21st December, 2017), Faraday (19th December, 2017), HeXeN (19th December, 2017), Locksmith Hungary (21st December, 2017), sumi1 (11th May, 2018)
  13. #325
    Nov 2014
    1) Programming chevrolet spark lt 2015 (id48) ok, spark europe ok
    2) Program chevrolet spark GT lt 2016 (8e) pre-code spark 8e for tango, programming ok, order 2 keys cycled.
    3) Program chevrolet traker 2016 (Procedure similar to chevrolet cruze)
    4) add key and remote control programming subaru outback 2015 (you need a programmed key) (the machine flashes when adding a key, it's a bit scary) note: control programming was done by subaru europe
    others:
    (mg china car) models 3, 5, 350 and gt, all can be programmed, they only need a pin (tp12 white)
    (donfeng china car) model s30 ok, need pin (tp12 white)
    (Greatwall china car) wingle 5 ok, need pin, id48
    To improve:
    I agree with some previous posts, I have not been able to program Ford for a while.
    I have finished working with skp900 or another team, something is wrong
    In my workshop we have done many programming, I do not remember them all, I will increase the list as I remember them, greetings, I hope you will be of help.
  14. The Following 5 Users Say Thank You to elmelor For This Useful Post:
    kronk92 (21st December, 2017), lalaina74 (21st December, 2017), maybach_ (24th December, 2017), norman1967 (21st December, 2017), ucokseparoh (31st December, 2017)
  15. #326
    HeXeN's Avatar
    Mar 2015
    Quote Originally Posted by elmelor View Post
    Have you tried with older SW version from your SD card?
  16. #327
    Nov 2014
    I'm going to do tests when Ford enters the workshop for lost key, there I will try different versions, to see if there is a real problem or just bad luck.
  17. #328
    Nov 2014
    Volkswagen gol 2011 Brazil (trend) immo 3.5 (need pin) --> program ok
    - You can get pin from the ecu and Eeprom 95040 or read with fvdi
  18. #329
    honingkoning's Avatar
    Dessert
    Megane 2005 keylearning Very fast.
    Read pin first it gives 4 pincodes you have to enter it manually.
    All ok, keyfob is also learned.
    Wbr Adam.
  19. The Following User Says Thank You to honingkoning For This Useful Post:
    maybach_ (11th January, 2018)
  20. #330
    Dessert
    Peugeot 206 2006 keylearning ok.
    Pin needed ofcourse
  21. The Following User Says Thank You to honingkoning For This Useful Post:
