Page 26 of 35 FirstFirst ... 162122232425262728293031 ... LastLast
Results 376 to 390 of 521
  1. #376
    hivrich's Avatar
    Sep 2012
    Ukraine
    Ssang Yong Rexton 2011 add key + remote - OK
  2. The Following 3 Users Say Thank You to hivrich For This Useful Post:
    Faraday (3rd April, 2018), lalaina74 (5th April, 2018), maybach_ (26th April, 2018)
  3. #377
    Dodge Ram 1500 2014, add keyfob (fobik) not ok - key locked
  4. #378
    Apr 2017
    what did the device show on screen when failed?
  5. #379
    HeXeN's Avatar
    Mar 2015
    C-MAX 2014 add smartkey 80bit - OK
    I think I went via Focus... v31.08 > China Ford > 2012-
    New updates are sh*t. v32.04 No communication.
    Do not update your tool until you backup old soft from SD card.
  6. The Following 3 Users Say Thank You to HeXeN For This Useful Post:
    Nymike (9th April, 2018), ROMIR (28th November, 2018), ucokseparoh (31st May, 2018)
  7. #380
    It's possible add key Renault megane 2007, smart card 4 buttons with x300 full?
    Thanks.
  8. #381
    Apr 2018
    Yes, one of my friend tried this
  9. #382
    Apr 2018
    Hello, which device?
  10. #383
    Nov 2015
    UK
    X100 plus.
    Can it do Mitsubishi colt 2008.
    Thanks.
  11. #384
    Apr 2018
    Quote Originally Posted by Buddy41 View Post
    X100 plus.
    Thanks.
    You can enter the device list to check
  12. #385
    May 2012
    italia
    Pugeot 307 1.6 petrol bosch m7.4.4 can not make ecu virgin adaptation.....I resolved with launch
  13. #386
    Mar 2018
    East Africa
    Hi guys can the X100 program wireless remote onto 2008 Nissan note with knob.
    Customer lost smart key but still has blade key.
    Sent from my NX563J using Tapatalk
  14. #387
    Apr 2018
    2008 Nissan which model?
  15. #388
    Mar 2018
    East Africa
    Nissan Note E11, JDM. I can calculate 4 digit pin, but I've tried all options on Nissan v31.45 but I can't seem to add the key.
    The key is new from dealer, correct frequency 315, and battery is OK and it's transmitting. Does this model require getting to the immobiliser for any reason or it should be just a simple fix?
  16. #389
    Jun 2013
    Quote Originally Posted by royalkey View Post
    Take out the key blade, and scan it. To verify that there is no transponder inside it. If it is filled with silicon.
    If it is two transponders close to each other, when doing programming. This problem will occur.
    I have experienced this. New CN key delivered from UK.
    But maybe your problem is something else.
  17. #390
    Mar 2018
    East Africa
    Quote Originally Posted by Weasel3 View Post
    Yes it does have transponder id46, the key on the smart key isn't cut yet so I can't insert it into the knob, I also haven't programmed the transponder as my key tool won't copy onto Nissan original chip.
    I was thinking once the remote programming works it should be able to unlock and start the car as its a keyless system..
