Page 27 of 35 FirstFirst ... 172223242526272829303132 ... LastLast
Results 391 to 405 of 521
  1. #391
    Jun 2013
    I see you scanned the hole smart key.
    And I want you to scan only the key blade.
    Remove it from the smart key and do the scan.
    Then you can verify that keyblade is empty.
  2. #392
    Mar 2018
    East Africa
    I scanned the emergency key on it's own and it's also a blank id46.
    Quote Originally Posted by Weasel3 View Post
    Sent from my NX563J using Tapatalk
  3. #393
    Jun 2013
    Then you remove the emergency key blade out of the vehicle.
    Place it on the bench outside the car.
    And try one more time to program the smart key to the vehicle.
    It should work.
    I verified this myself scanning a friends vehicle, to confirm that in my case the blade should be empty.
    And it worked out all right, after this.
  4. The Following User Says Thank You to Weasel3 For This Useful Post:
    royalkey (25th May, 2018)
  5. #394
    Mar 2018
    East Africa
    Ok will give it a try and report back..
    It should work.
  6. #395
    Oct 2017
    Quote Originally Posted by AndyCZ View Post
    Can X100pro program Landrover Freelander 2 key?
    Did you tried LandRover FreeLander 2 with x100 ...???
    Envoyé de mon SM-N9005 en utilisant Tapatalk
  7. #396
    Oct 2012
    Touareg 2008? odo ok
  8. #397
    Hampshire
    Polo 9N , lost chip, pulled pin and programmed in the TP chip in no time.
  9. #398
    Jul 2013
    VW Sharan 2002 1.9tdi fail to pull pin code.
  10. #399
    dimitar's Avatar
    Ford focus 2002 key erase...key programing....add key ....... All fail
    Done with forscan
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  11. #400
    lexus 2007 smart key add all versions not work
    with launch same car no problem
  12. #401
    dimitar's Avatar
    Honda jazz 2012 add key ok
    50w Soldering Iron
    Chisel
    Sometimes Hammer
  13. #402
    Jun 2018
    is it good for vw and audi ... over 2013?
  14. #403
    honingkoning's Avatar
    Dessert
    Quote Originally Posted by azeem786 View Post
    Hahaha just buy vag k+can 1.4 for this cars
  15. #404
    hcip's Avatar
    From the heaven of paradise in the middle of happiness|hobby:__Bedtime| Sex:Female|Status:Not_Virgin
    OBDSTAR XDP 300 Smartkey for toyota corolla altis 2008 year cannot add key/remote (Program success but the key doesnt learn to a car)
    OBDSTAR X100 do it
    Stupidity is not a disease, because there are no existing hospitals for Idiots!
  16. The Following User Says Thank You to hcip For This Useful Post:
    Faraday (29th June, 2018)
  17. #405
    Apr 2016
    x300 dp Toyota emulators works?
