Page 4 of 35 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 521
  1. #46
    dyzio's Avatar
    Jan 2014
    Racek
    mazda 5 2006 all key lost ok
  2. The Following 2 Users Say Thank You to dyzio For This Useful Post:
    ibratex (19th October, 2016), zckariya70 (19th October, 2016)
  3. #47
    ibratex's Avatar
    Jul 2015
    angola
    Quote Originally Posted by ucokseparoh View Post
    Hi mate..were those Prado all key lost or simply making a spare? I have not had any luck with Toyota yet.
    Anyway.. just got a report from a friend,2010 Ford Ranger,4D63.. all key lost OK.
    I also didnt have luck with corolla .. but those orado was only program keys ...i asked obdstar enginere he said it can do prado 2014 all key lost ...but i didnt try yet ...
    Sent from my SM-G900H using Tapatalk
  4. The Following 2 Users Say Thank You to ibratex For This Useful Post:
    ucokseparoh (20th October, 2016), zckariya70 (19th October, 2016)
  5. #48
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Honda Amaze petrol 2015 key + remote in 15 min ok
    Nothing will remain in this World , Everything will come to END!
    THINK POSITIVE NOTHING IS IMPOSSIBLE
    Please do not spam by PM asking for help. Use forum, that is why we are here.
  6. The Following User Says Thank You to zckariya70 For This Useful Post:
    eliaselias (20th October, 2016)
  7. #49
    Oct 2016
    FRANCE
    i tested have good work
  8. #50
    Aug 2015
    BEHIND YOU
    toyota fortuner 2009 NOT ok .. job done with skp
    IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
  9. The Following 3 Users Say Thank You to eliaselias For This Useful Post:
    ibratex (20th October, 2016), ucokseparoh (20th October, 2016), zckariya70 (21st October, 2016)
  10. #51
    ucokseparoh's Avatar
    Aug 2015
    Indonesia
    Quote Originally Posted by eliaselias View Post
    thanks for that good news mate.. i know now that it's not only me which had a bad luck with Toyota with this tool.
  11. #52
    Aug 2015
    BEHIND YOU
    this fortuner was with 4d67 and was unable to do
    next time i will try toyota with G and H chip soon
  12. The Following 2 Users Say Thank You to eliaselias For This Useful Post:
  13. #53
    zckariya70's Avatar
    Jan 2014
    Inside EEPROM
    Anybody did Honda city id tec diesel 2015 ................?
  14. #54
    stalonerambo
    Guest
    yes, and old sbb can do it , so now problem
  15. #55
    Aug 2015
    Indonesia
    Failed again on Toyota remote. Fortuner 2007.
    Connected the cable to the OBD port ==> ignition ON ==> chose type 1,2 and 3 one after another ==> got prompted on the screen "communication breakdown bla bla bla ... main line is connected bla bla bla " ==> pressed ENT ==> nothing happenned.
    I even tried it with ignition ACC/Off.. result was the same..nothing happened.
    Finished the job manually.
  16. The Following 2 Users Say Thank You to ucokseparoh For This Useful Post:
    eliaselias (1st November, 2016), ibratex (22nd October, 2016)
  17. #56
    Aug 2015
    BEHIND YOU
    chevrolet camaro 2010
    ALL KEY LOST ok
    but you have to put security code...x100pro can not read it
  18. #57
    Sep 2016
    He can read pin psa and adjuste odometre psa?
  19. #58
    Sep 2016
    - Toyota Harrier 2005. Adding a spare..both chip and remote programming not work.
    - Toyota Hilux 2009 G-chip. Adding a spare.. both chip and remote programming not work.
    - Toyota Vios 2014 G-chip. Adding a spare.. both chip and remote programming not work.
    - Honda cars,both making a spare and all key lost and remote programming,so far never failed.
    - Mitsubishi Pajero 2014. All key lost OK.
    Temporary conclusion : useless for Toyota
    Thanks for your feeback. Regarding Toyota(no smart systme), primary key and secondary key has been typed. If the primary key lost, please program directly. If secondary key lost, please program same as ALL kEY LOST( which need to initialize the data with EEPROm adapter first and program as normal) Thanks
  20. #59
    Sep 2016
    Quote Originally Posted by iamfooser View Post
    I think it is user problem. Your method is wrong as the instructions are not clear. So far never fail on toyota before for me.
    Sent from my EVA-L19 using Tapatalk
    yes, the promariy key and scondary key need to be tell. And EEPROM adapter can used to do ALL KEY LOST for toyota.
  21. #60
    Aug 2015
    Indonesia
    I don't think it's a user problem Susan.. i just talked to a friend who own that old x100+.. he told me that AT LEAST for Toyota 4D67 he can do ALL KEY LOST without having to touch the eeprom or immobox. Straight from OBD. Once the device connected to the car,option for ALL KEY LOST is there. As for me,once the device connected to the car,options available only :
    1. Erase keys
    2. Reset immobilizer
    3. Engine ECU or something like that.. but no option for ALL KEY LOST.
    at least for 4D67,old x100+ is much better than the PRO. x100+ can do Toyota 4D67 ALL KEY LOST..it just doesn't work for Toyota G,which is fine as i have Tango as a back up.
  22. The Following User Says Thank You to ucokseparoh For This Useful Post:
