Dodge Ram 1500 2014, add keyfob (fobik) not ok - key locked
what did the device show on screen when failed?
C-MAX 2014 add smartkey 80bit - OK
I think I went via Focus... v31.08 > China Ford > 2012-
New updates are sh*t. v32.04 No communication.
Do not update your tool until you backup old soft from SD card.
Nymike (9th April, 2018), ROMIR (28th November, 2018), ucokseparoh (31st May, 2018)
It's possible add key Renault megane 2007, smart card 4 buttons with x300 full?
Thanks.
Yes, one of my friend tried this
Hello, which device?
X100 plus.
Can it do Mitsubishi colt 2008.
Thanks.
Pugeot 307 1.6 petrol bosch m7.4.4 can not make ecu virgin adaptation.....I resolved with launch
Hi guys can the X100 program wireless remote onto 2008 Nissan note with knob.
Customer lost smart key but still has blade key.
Sent from my NX563J using Tapatalk
2008 Nissan which model?
Nissan Note E11, JDM. I can calculate 4 digit pin, but I've tried all options on Nissan v31.45 but I can't seem to add the key.
The key is new from dealer, correct frequency 315, and battery is OK and it's transmitting. Does this model require getting to the immobiliser for any reason or it should be just a simple fix?
Take out the key blade, and scan it. To verify that there is no transponder inside it. If it is filled with silicon.
If it is two transponders close to each other, when doing programming. This problem will occur.
I have experienced this. New CN key delivered from UK.
But maybe your problem is something else.
Yes it does have transponder id46, the key on the smart key isn't cut yet so I can't insert it into the knob, I also haven't programmed the transponder as my key tool won't copy onto Nissan original chip.
I was thinking once the remote programming works it should be able to unlock and start the car as its a keyless system..
