New updates will have 47 on the menu Video will be uploaded on Tuesday.
Ray-Ray, is there a video or could there be a video on the pulling page one and two from registered proxy to get pin code. I've never done that, not sure where to start. I've been doing Hyundai proxy but with dealer reluctantly supplying code to used dealer, whose Hyundai's I do.
camelgd (17th December, 2017)
Many thanks, Ray, I have a lot of customers that are impressed with what I can do for them with APP.
More to come soon for the USA market. In January there engineer that works on Europe cars will be here testing.
3 new system will be added to the menu, all have been tested & complete.
1. Subaru all lost keys “G” with a 16 min. Tested working. Release by next Friday.
2. Ford F series Truck (Flipkey) All Lost Keys programs within 2 min.
3. Ford 128 bit new Proxy with chrome front, All Lost Keys takes about 2 min. To complete.
camelgd (22nd December, 2017)
Have been looking forward to the Ford updates, Thanks!
Ray-ray just a heads up GM still shows “Load dynamic Fail” when I try to connect. I remember it did the same thing with hyundai with the last update. Sometimes when updates are available it does mess up the other software that are not included in the update itself. (Ps90)
Give your serial number so that I can fix it.
BMW Cas system added we will start checking today.
Weasel3 (27th December, 2017)
Just got the 2017 F150 download, can't wait to try it.
- Hyundai & Kia New PIN Code Read: No more buying PINs from the dealer (coming Q3 2017)
- Audi/VW 2013-2016 Programming for Add-A-Key (coming Q3 2017)
- Audi/VW 2013-2016 Programming for All-Keys-Lost (coming Q3 2017)
- GM Pin Code Reading (coming Q3 2017)
- Chrysler Type1 & Type2 PIN Read Via EEPROM (coming Q3 2017)
- Subaru 2017 MSOP EEPROM In-Circuit Programming w/ Adapter (coming 2017)
- Dodge/Mercedes Sprinter Bypass & Programming (coming Q3 2017)
- Transponder Motorcycle Programming (coming 2017)
recently added and in testing
- BMW CAS Key Programming (coming 2017)
- Subaru G-Key (80-Bit) All-Keys Lost Programming (coming 2017)
- Ford F series Truck (Flipkey) All Lost Keys programs within 2 min.
- Ford 128 bit new Proxy
anything else interesting coming up?
Aren't we in 2018? A bunch of those features were promised to be complete in 2016... Maybe we will see them in 2019 or 2020
Hi Ray-ray
Did a 2004 Toyota Prado all key lost, problem was that didn't seem to work, immo light was still blinking after reset and car did not start, but after reset with pad pro2 with no success, other toyota works fine, I did it with tango and emulate key on cn2, now I have the problem that ignition solenoid is active and immo light blinking, bypass ignition solenoid, car is starting, found out when i did with tango is a two key storage, both matched with tango. How can I correct the solenoid and immo light problem? as I don't know if xtool reset works on dual storage or change the file somehow.
Some people just want glory instead of acknowledgment.
Thanks and reputation is earned, not ask for.
Have a nice day.
I don’t have any china xtool to test here in the USA. The AutoProPad made by xtool is different unit then what you have.
____________
Not Happy return it! I’m still working on my end and things are moving along.
Ford 128 proxy system working.
nissan easy to use menu working.
subaru All Lost G working.
lexus/Toyota All is working.
mercedes Keys in truck is working.
Bmw Cas 1,2,3,3+ added but not tested.
All toyota and Lexus working. So I'm assuming you are resetting 4C system also... Correct? And Im talking about the systems that are resettable via obd.
