Page 52 of 78 FirstFirst ... 242474849505152535455565762 ... LastLast
Results 766 to 780 of 1158
  1. #766
    Mar 2017
    Have never been able to pull a Buick pin with the autopropad before....Went to car with latest GM version that has simplified pin system. Did a great job getting pin from BCM on a 2011 lacrosse.
  2. The Following User Says Thank You to ps80l For This Useful Post:
    ray-ray (20th May, 2018)
  3. #767
    Mar 2017
    Tried on 98 Ford expedition(PATS1)
    Worked but timer has issue. Runs very slow. Procedure took about 8 minutes but time had only reached about 3.
  4. #768
    ray-ray's Avatar
    Thanks, so there is a timing issue with pats1 I will look into it. We are starting on the European Cars next. I will post on any new development.
  5. #769
    Mar 2017
    Ford 27.12 looks great!! The layout is perfect!!
    Chrysler new features are also great!! Now I just need to get some 17+ Pacifica keys.
  6. #770
    newone's Avatar
    Oct 2016
    Quote Originally Posted by ray-ray View Post
    hello ray ray,can you give more info what european cars are on your plan?
  7. #771
    ray-ray's Avatar
    Audi/vw , bmw/rangerover, Fiat/Alfa, Mercedes ml series
  8. #772
    newone's Avatar
    Oct 2016
    is there an estimated time for those?i was planning to buy smart pro but i see what you do with the software you develop and also the love and effort you put in your work,if it will not take much time i could wait then
  9. #773
    ray-ray's Avatar
    Wait the engineer is her for 1 month to fix the issue.
  10. #774
    Mar 2014
    Greece
    we need a tool that has coverage for European market.
  11. #775
    Mar 2017
    I suggested to Erik that the Pin reading menu be modified to make it easier to get pin. Im pretty sure he will have it setup for next update.
  12. #776
    ray-ray's Avatar
    Yes you have been a great help to the team.
  13. #777
    camelgd's Avatar
    Jan 2011
    South Illinois
    Ray-Ray, Is there anymore info on 2019 Ford F150 not being able to add key? I've been told by dealer you have to take all keys out and them add them back in. By the way, the tool is making me look pretty good with local dealer, spend a lot of time there doing program overflow, and they are very happy with results.
  14. #778
    ray-ray's Avatar
    Will be testing a lot more, now that the engineer are hear. Ford is releasing new protocol for 2019 looking into it.
  15. #779
    camelgd's Avatar
    Jan 2011
    South Illinois
    2011 F150 ECU locked up by customer with unprogrammed key. Does Autopro pad have shortcut around ECU locked up? If not, anyone know any shortcuts around this problem?
  16. #780
    ray-ray's Avatar
    Try clearing codes from the diagnostic side, then go to immo.
  17. The Following User Says Thank You to ray-ray For This Useful Post:
    camelgd (6th July, 2018)
