Page 1 of 78 1234561151 ... LastLast
Results 1 to 15 of 1158
Hybrid View
    ray-ray's Avatar
    Nov 2009
    Default PS80/PS90 tablet key programming
    Today the engineer from X-Tooltech and me run test on resetting immo. for all lost keys Toyota "h" key and Proxy USA. There tool has no opition to reset immo. It just support change to new immo. And then programming. So there was a obd2 cable with 3 plug in (PC, PS90, PVM)
    PS90 recording in android os, PC recording in windows, PVM programming "Reset" function.
    That data is then compared from Window to Android and is broken down to learn the command code.
  2. The Following 5 Users Say Thank You to ray-ray For This Useful Post:
    Automat (18th October, 2016), DOUGLASDL (9th February, 2017), lioncam (4th October, 2016), milehighlockdoc (21st November, 2018), ucokseparoh (4th October, 2016)
  3. #2
    ray-ray's Avatar
    Nov 2009
    Today we ran the PVM program with the computer and no car. So it was like connecting to the car but no car. These is where the break down to get the commands are done. After that we do it in android os, so there 2 os that the command can work under. (B5)
    command for register key.
  4. The Following 4 Users Say Thank You to ray-ray For This Useful Post:
    Automat (18th October, 2016), keysmith (7th October, 2016), milehighlockdoc (21st November, 2018), samirrr (24th April, 2017)
  5. #3
    ray-ray's Avatar
    Nov 2009
    X-Tool by Obdstar is not the same as X-Tooltech maker of ps80/90 or x100 pad pro,x100 pad pro 2,ex400,ez500 these company has proven to come to the USA and work with me to improve there tool.
  6. The Following 4 Users Say Thank You to ray-ray For This Useful Post:
    Automat (18th October, 2016), keysmith (7th October, 2016), mexanico1971 (28th June, 2018), milehighlockdoc (21st November, 2018)
  7. #4
    ray-ray's Avatar
    Nov 2009
    Soon the new tablet (X100 pro2) will be release to the Asian market. The USA version will be release by December (USA Pro1) today we add the qwick reset immo. Ford,mercury,Lincoln no 10minute wait. Toyota "G" & "H" all lost key reset will be tested in the a.m. Next to work on is Mazda 6 2016 system.
  8. The Following 5 Users Say Thank You to ray-ray For This Useful Post:
    Automat (17th October, 2016), keysmith (7th October, 2016), lion0304 (5th October, 2016), milehighlockdoc (21st November, 2018), stickmuon (8th October, 2016)
  9. #5
    ray-ray's Avatar
    Nov 2009
    Today we test No waiting all lost keys on ford,mercury,Lincoln all pass 20 different cars and trucks. Next thing to add is parameter reset to marry all modules once something has been change. We recorded pats 5,6 next week will do the hec system.
  10. The Following 4 Users Say Thank You to ray-ray For This Useful Post:
    Automat (17th October, 2016), keysmith (7th October, 2016), milehighlockdoc (21st November, 2018), stickmuon (8th October, 2016)
  11. #6
    ray-ray's Avatar
    Nov 2009
    2016 Ford Fusion "No Pin Code" all lost key 2min. To program new Proxy. Tested WORKS !!!
    GM Pin read function is being added we found the command. Also GM new function add re-Write vin number.
  12. The Following 3 Users Say Thank You to ray-ray For This Useful Post:
  13. #7
    ray-ray's Avatar
    Nov 2009
    I will be closing these thread soon you will all see the work I put behind these tablet. I will be at aapex & sema show in Vegas to release the tool to the USA market. American Key Supply will have YouTube Channel promoting all aspects of the tablet. Once again for all OBDSTAR IS FAKE COMPANY ( with no engineer working to improve there tool there update are bought. On the other hand Xtooltech has developed and correct thing on the tablet and are here with me in the USA building a new market.
  14. The Following 8 Users Say Thank You to ray-ray For This Useful Post:
    Automat (18th October, 2016), AUTOREPAIR1 (14th March, 2017), cklair (19th June, 2017), duplikeytor (20th February, 2017), mehmet becker (31st August, 2017), milehighlockdoc (21st November, 2018), stickmuon (8th October, 2016)
  15. #8
    Jan 2010
    Quote Originally Posted by ray-ray View Post
    Not sure about that xtool are the ones that released many many different tools even before x100 all failed, they also took advantage of obdstars name in the x100.
    obdstar released lots before xtool.
    although I'm sure with your help this new tool will be good for the USA market.
  16. The Following User Says Thank You to paul_12345 For This Useful Post:
    mikajna (8th October, 2016)
  17. #9
    Dec 2016
    USA
    is the x100 good for the usa or no ?
  18. #10
    Apr 2017
    Quote Originally Posted by devintche View Post
    use it yourself always make sense
    what other people say doesn't proved enough
  19. #11
    lwood's Avatar
    Mar 2010
    city of angels
    wow this tool never make it??
    i was hoping would be good tool to buy.
    i watch a youtube video of a locksmith couldnt do fords. had to return his propad
    DON'T JUST SAY PRESS IT.....
  20. #12
    ray-ray's Avatar
    Nov 2009
    I've been getting my info from there engineer who have left Autel and join forces with Xtooltech to release a stable diagnostics tablet. After GM and Ford court battle with Autel they are now going into robotics and dropping there effort in diagnostics.
  21. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    Automat (18th October, 2016), bobby maze (24th March, 2017)
  22. #13
    lion0304's Avatar
    Oct 2014
    It seem your PS90 has the clone called X100 PAD2:
    https://www.aliexpress.com/item/DHL-...7-b513cb520558
  23. #14
    ray-ray's Avatar
    Nov 2009
    Not a clone original that's there new pad, but people still what everything for nothing. The USA version will only work with USA region cars.
    ford Fusion is working correctly but 2016 mustang and F150 failed to read rolling pin and bypass. They are trying to work it out, even thou the MVP pro day it the same protcal.
  24. The Following User Says Thank You to ray-ray For This Useful Post:
  25. #15
    lion0304's Avatar
    Oct 2014
    Yes i know it is new X100 pad and original from Xtool. Clone meaning it added transponder coil like PS90. I'm in European region, so PS90 cannot be my next purchase?
    It also write: VAG 4 +5th added, but does it work like chinese said?
