Page 8 of 78 FirstFirst ... 3456789101112131858 ... LastLast
Results 106 to 120 of 1158
  1. #106
    ray-ray's Avatar
    Nov 2009
    The firmware will be change and your eeprom and tag tool with other goodies will be sent to you as soon I fill there ready to be ship. I'm also working on a calculator that will find key in dump and display it for you. At that point you could write the Keylogic to a chip to start the car or add your value to the calculator to add back to the dump.
  2. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    Automat (31st March, 2017), mehmet becker (31st August, 2017)
  3. #107
    Jan 2017
    USA ����
    whats wrong with them now? the eeprom and tag tool that is
  4. #108
    ray-ray's Avatar
    Nov 2009
    I wanted to add Pomona clips and the goklip with the pogo pins for in circuit reading. I also going the add a Ariel tester and the new style power packs. I want to make sure you have all the tool it take to get the job done.
  5. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
  6. #109
    Mar 2017
    Ray. I tried everything to remove all the chinese cars from the Immo menu and did not succeed. How do I do it?
  7. #110
    ray-ray's Avatar
    Nov 2009
    Erik has your number he can teamview your tablet and remove those files.
  8. #111
    Mar 2017
    Erik tweaked the layout of my machine. Now it's starting to look like the machine AKS has promised. Thanks
  9. #112
    Mar 2017
    Drove 40 minutes to go to my very first car with PS80. 2013 Kia Forte Prox... It failed!! What a waste of time...
  10. The Following User Says Thank You to ps80l For This Useful Post:
    phuckyall (30th March, 2017)
  11. #113
    Jan 2017
    USA ����
    http://autoproapp.com/AutoProPAD-App...-Guide-1.0.htm
    How did it fail?
    Did you have hazards on?
    Did you start with ignition off?
  12. #114
    Mar 2017
    I have programmed several hyundai/kia prox. The hazard light is not really required. Supposedly it wakes up the computer but I have never done it when using tcode. I did try the hazard light and steping on the gas pedal/open close doors. This also did not work. Get a fail to communicate after I put code.
    Text Erick and he told me they are aware their is a problem with this system. So I asked why not remove it from the menu.... Answer... Because we might forget about working on it. So I suggest everyone contact tech support and verify a specific system will work before taking on job and driving there.
  13. The Following 2 Users Say Thank You to ps80l For This Useful Post:
    kronk92 (28th March, 2017), phuckyall (30th March, 2017)
  14. #115
    Top Poster FUSED:'s Avatar
    Apr 2016
    Then XTOOL PAD 2 is for American market
  15. #116
    Jan 2017
    USA ����
    Quote Originally Posted by FUSED: View Post
    no
    ps80l and ps90l and autopropad are for usa
  16. #117
    Mar 2017
    2nd car I try and it fails. 2012 Focus. Programmed fine with Smart Box.
  17. The Following User Says Thank You to ps80l For This Useful Post:
    phuckyall (31st March, 2017)
  18. #118
    ray-ray's Avatar
    Nov 2009
    With "US Ford" should have clear that problem, I'll check on it.
  19. #119
    Mar 2017
    Yes. USA FORD
    PS80 made the dash flicker and then the dash went very dim while it searched for password. Found it and then got an error.
    With SB the dash stay fully lit throughout the whole procedure.
  20. The Following User Says Thank You to ps80l For This Useful Post:
    phuckyall (2nd April, 2017)
  21. #120
    Mar 2017
    Went to try PS80 on a 2012 toyota all keys lost.
    Pressed all keys lost and boom! Car was reset. Wow! Never used a machine that has done a reset that quick. Thumbs up!
  22. The Following 2 Users Say Thank You to ps80l For This Useful Post:
    Automat (8th April, 2017), phuckyall (2nd April, 2017)
