Autobouquetsmaker
Results 1 to 9 of 9
    Default Autobouquetsmaker
    hello
    i havent updated my box for a while and iv found bt sports 2 is missing from my Autobouquets is Autobouquetsmaker a newer version of this? if so where do i get it and how do i install it. i want bt sports to see a friend davy grant fight tomorrow in the ufc.
    dm800se openpli 3.0
    please help thanks
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    Two different plugins that do the same thing one's called autobouquetsmakers and the other is called autobouquets. I don't use openpli or dm800se so my help will be limited.
    You could try to do a software update this will update your ABM plugin then do a scan or remove the ABM plugin and reinstall the ABM plugin via the plugins menu.
    Or or get an upto date ABM.ipk and install via the local extensions menu, do a Google search for one as I'm on my phone so can't link to one at the mo.
  3. The Following User Says Thank You to martin035 For This Useful Post:
    darguewin (6th October, 2016)
    thanks for you help, iv done a lot of searches and hvent been able to find any thing thats new, i have autoboquets but this is the one that has missing channels. iv tried to find the autoboquetsmaker ipk but i cant see it anywhere, will have a little play and see what i can do. any more advice is welcom
    maca's Avatar
    Feb 2009
    liverpool
    Go to SSP 1 and do complete scan and this should bring in all channels.
  6. The Following User Says Thank You to maca For This Useful Post:
    will give it a try now! running out of time
    well update, full scan didnt work. no idea what to do. arghhhhhh
  8. #6
    martin035's Avatar
    Apr 2014
    Stuck in Fife
    These are the latest .ipk's I could find for autobouquets & autobouquetsmaker would advice to use one or the other and as you have autobouquets already install try that one first.
    Unzip, FTP then .ipk file to your DM800 /tmp and install via the local extensions menu
  9. The Following User Says Thank You to martin035 For This Useful Post:
    darguewin (7th October, 2016)
  10. #7
    thanks mate. will give it a go as soon as i get home from work. i couldnt find anything, but its always the case when you have a rush on. will update later with the results
  11. #8
    they wouldnt go on the image so i will need to find a new image and try something else, any one running a stable image on their dm800 se? this openpli 3.0 image is good but its old now
  12. #9
    Dec 2016
    Thanks Martin,
    Was looking for this as the plugin version wouldnt load in newer nightly build of openatv
  13. The Following 2 Users Say Thank You to forol For This Useful Post:
    charley (12th February, 2017)
