immo off free for all - Page 4
Page 4 of 150 FirstFirst 1234567891454104 ... LastLast
Results 46 to 60 of 2247
  1. #46
    Jul 2016
    Default Starex immo off
    Pls, hepl me. Thank so much.
  2. The Following 2 Users Say Thank You to hungautoviet For This Useful Post:
    estwood68 (25th March, 2019), Kliosi (9th May, 2020)
  3. #47
    Nov 2015
    hello friends I need immo off for this ecu iaw 6lp1. 45 Peugeot 407 sw 160.732.034 sw 9655355180 you can help me thank you.
  4. #48
    hi, is it possible to immo off this file ? alfa gt 3.2v6
  5. The Following User Says Thank You to boon33 For This Useful Post:
  6. #49
    Oct 2013
    Default please help 11 Camry immo off.
    can someone please help, 2011 Toyota Camry, got car from action and it cam with a key with keyless entry. The Immo box wouldn't communicate with my programmer, so I purchased a new Immo module and it now communicates, but I still cant get to program key to start car failed to program. The only thing I was able to program was the remote keyless part that's open/locks doors. If there a way to baypass this system I can really use someones help. I'm posting 2 dumps, one original dump that came from the bad Immo shows1 and Dump2 came from new immo. Thanks Lou
  7. The Following User Says Thank You to Airbagtech For This Useful Post:
  8. #50
    Jul 2016
    Default Immo off Fiat Doblo Iaw 5Nf.T4
    Could you help me immo the Fiat Doblo (eprom 95160). Thanks
  9. The Following User Says Thank You to hungautoviet For This Useful Post:
  10. #51
    Oct 2013
    Hello can you please help me on 2011 Toyota Camry type4, I'll post 2 dumps if you want maybe do both, or the one you think i should use. Dump 1 is from the original Immo module, but had no communication with scanner, but 93C66 eeprom still good, so I saved the dump. Dump 2 came from a used Immo I purchased from Epay and has good communication, but yet failed to program key. attached are both Dumps please reset. Thank you Loue
  11. The Following User Says Thank You to Airbagtech For This Useful Post:
  12. #52
    sorry for bad english, can someone helpme? i will atach the file that i did read whit x100.
    the ecu is bosh motronic 8693 0021 and the eprom inside is 95080
    the inmobox have this code HA00-67-5G2M1 and the eprom inside is 24LC02BI
  13. The Following User Says Thank You to arielcom For This Useful Post:
  14. #53
    May 2017
    S110140201A 8200326395 29F200BB renault clio 2005 1.2
    i don't know if it have k or can line
    S110140201A 8200326395 29F200BB renault clio 2005 1.2 gibo 17-5-17.rar
  15. #54
    Ladysmith,KZN,South Africa
    Hi, I have a Nissan Zexel 407917-114 1 ecu, i changed the immo box with a new one, but still wont start, kindly let me know which chip to read
    and post dump. Is there an immo off solution for this ecu? thanks.
  16. #55
    May 2017
    Hi friend..hope you are there.i will appreciate a lot if i get toyota fielder immo off dump
    ..i will post the fill.thanks in advance
  17. #56
    May 2017
    L56R01.rar
    toyota fielder ECU 89666-12210
    1ZZ-FE M/T
  18. #57
    Apr 2014
    Can you do Ducati Hypermotard 796 immo off?
    Sent from my SAMSUNG-SM-N910A using Tapatalk
  19. #58
    Sep 2016
    Hi, need immo off for Hyundai Terracan ecu Delphi DDCR R0410C047B Serial no. 0000110 EVG 39112-4X510
    TNX
  20. #59
    gueswhat's Avatar
    Nov 2016
    World wide
    hello friend can you help me with immo off a
    file
    thank u for u time
  21. #60
    Aug 2016
    Stip
    honda cbr600rr 3788-mee-d01 93c66 8bit.rari need immo off for honda cbr600 2005 ecu keihin 3788 mee-do1
