Here is file 24C16
I have a powersteering as having fault
DF002 (C1608)
DF035 (C1606)
C1605
Is this Eeprom fault or is it hardware fault in steering column?
I cant see 24C16 on top side of pcb... So is it possible to read by pin connector and any tool?
Or do I need to desolder all joints and take away pcb to read 24C16?
Renault
8200246631B
TRW
50300374
Skickat fr?n min iPhone med Tapatalk
Here is file 24C16
satesquio (28th December, 2016)
Hope that someone can help me
Here is pinout for reading 24C16 bu UUSP-S + pinout for Eeprom 24C16
armpower (31st March, 2020), autocrypto (16th February, 2023), bobbik (21st February, 2017), cheaper (8th February, 2024), chiorbeq (11th March, 2023), cleiwil (27th February, 2024), conan981 (1st March, 2019), dawidhubert (10th August, 2023), Donabe (19th March, 2019), DOUGLASDL (20th September, 2017), dzt1399 (23rd January, 2024), ebbie01 (15th October, 2022), eleeinidis (29th March, 2024), Heleje (7th August, 2023), janusz21 (27th November, 2016), kamelkamel (11th October, 2023), kvadratas (22nd November, 2016), lion0304 (26th October, 2016), M3L3R (9th September, 2018), martinracing (5th September, 2017), masmiquel (26th November, 2018), multiplex1976 (13th August, 2018), nagybela (13th September, 2022), penteadonp (12th February, 2019), phorawa (6th December, 2018), rrr500 (5th February, 2023), spider-wifi (6th May, 2020), vavrich (18th November, 2021), Voltio87 (13th February, 2023), xifly18 (16th February, 2018), Yhoni (16th June, 2023)
I would do it like this
megane_virgin.rar
anarvaezing (23rd September, 2022), autocrypto (16th February, 2023), cleiwil (27th February, 2024), dawidhubert (10th August, 2023), korfi (8th May, 2022), quimet (13th March, 2023), soxten (9th October, 2016), vetal1504 (29th April, 2023)
Ah virgin file
Does it need to program by clip or does it work/coded when ignition goes on?
Need help, I have now fault DF054 and DF055 after programing on OEM workshop.
Please any as have info about this fault codes?
You need check all Mosfet and rework solder joints. DF002 can be hardware problem and next corrup the dump.
You can try my repair dump here
24C16+x8_orginal_repaired.rar
No THANKS, no HELP!!!
anarvaezing (23rd September, 2022), autoperfect (8th September, 2021), Brolk (21st September, 2021), Donabe (19th March, 2019), ebbie01 (15th October, 2022), el genio (7th June, 2021), Heleje (7th August, 2023), Hunter1206 (23rd January, 2024), ivandr1987 (1st June, 2022), julianobarcik (17th October, 2022), mastercracker (10th December, 2020), mecadriano (28th December, 2016), networker (13th July, 2021), paulolad (21st August, 2023), quimet (15th March, 2023), soufix (16th June, 2022), soxten (26th October, 2016), tynave (6th January, 2024), vetal1504 (29th April, 2023), Yhoni (16th June, 2023), Zestr80 (13th April, 2020)
this problem some times for data ST10 mcu
with clip can't program , only have config
you can read dump ST10 with xprog and post here
i try to checking dump
I have a nother used part here now.
I try to write virgin eeprom and reprogram by clip and hope it work!
Do I need to write virgin file if both have same part number?
There is no immo in power steering?
Does it work to mount a used directly in car?
Immo only in steering lock or?
Immo only in steering lock, not in column
soxten (15th November, 2016)
Hi Soxten, Mate how did you solved your problem ?
I need this info tooimmo is only in steering lock ,,so why need we then virgin dumps ?? it is just for fault codes or powerstering is paired to VIN nummer each different cars ?Does it work to mount a used directly in car?
