Page 3 of 4 FirstFirst 1234 LastLast
Results 31 to 45 of 51
  1. #31
    Youneselm's Avatar
    Nov 2010
    Default VW Golf Discover Pro MIB hack, navi activation and cp removal
    Yes mate, only when that car vin nr have left factory with those options activated. Only Then iT is posible with odis.....
    Br
  2. #32
    Jan 2018
    Quote Originally Posted by offsystem View Post
    Yes but the car had navi from factory or not?
    Had navi but never been activated
  3. #33
    Hello if you look to activation function in MIB pleas contact me via Pm.
  4. The Following User Says Thank You to skiba For This Useful Post:
    sprinks (21st May, 2018)
  5. #34
    Feb 2018
    Does anyone change the ops vwhicle image in MIB2?
  6. #35
    Mar 2018
    nec v850被定位在单元中
  7. #36
    Aug 2015
    Is the nec locked for reading with jtag?
  8. #37
    Oct 2011
    Would also like more info on how to get into V850 and removing CP
  9. #38
    Feb 2018
    va usa
    Quote Originally Posted by orbitmk View Post
    OPS vehicle image can be changed in ODIS by changing longcode bytes. Stored in Module 5F - Information Electronic -> Coding -> Long coding under byte 18, bit0, bit 1, and bit 2 control vehicle image. bit 0 deactivate, bit 1 active, bit 2 active -> golf; bit 0 active, bit 1 active, bit 2 deactivated -> GTI
  10. #39
    Mar 2013
    Hello, this is an interesting topic, I also have a problem with mib std2 pq. Used from another car, I put it to sharana 2012, the radio worked for some time but then there was a message about CP. Then I found out that if I did not put in the car, it was possible to mount a patch on the radio and that unfortunately it would work late. Now I am looking for a solution. I wonder if I want to disable Cp by delar or online, which functions will work and which do not, the car originally had a radio RNS315 with BT VOIC and Navigation and so left the factory. Only the radio was different, and now my question is jwhether it was enough to have these functions added to vin even though there was another radio?
  11. #40
    Jul 2014
    someone can help to activate functions
    my mib 1 has fail and I put a mib 2 and make CP on dealer but I lost navi bluethooth, voice
    maybe now someone found solution
  12. #41
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by unucip View Post
    if MIB 1 was factory , Dealer should enable activation according to your VIN, not just CP remove
  13. #42
    simaservis1108's Avatar
    Aug 2013
    Serbia,Belgrade
    Go to dealer and tell them to restore SVM activations based on your VIN number.
    All will work except navigation because MIB1 and MIB2 maps have different FEC code.
    Best is to buy MIB2 mapcare for your VIN,it is a lifetime map code,but it is available only in some countries.
  14. #43
    Aug 2015
    Quote Originally Posted by simaservis1108 View Post
    In which country is it available? Germany??
  15. #44
    Jul 2014
    Mib 2 mapcare ...I don't know what this is. There is a OEM code? Is something like upgrading mib with sd card?
    I know that some guys have solution for activate all the options in mib and they can do that with ODIS. There is a russian guy who knows everything about this and have solution for.
    Please don't ask me how because I'm looking solution.
    I went to my dealer vw. After 2 hours waiting they told me that nothing can be done. Only component protection. Because they don't know how to do that.
    Sent from my SM-G950F using Tapatalk
  16. #45
    Aug 2019
    Hi, my summer offer for you: Will patch your MIB2 image with everything enabled for free. Just PM me for more information. ps. dont PAY for WAREZ !
