Have done it for you,update it
jose9413 (26th July, 2017)
Please upload a picture of the key PCB,a picture of the erase error~
Mine definatly has a problem. I tried on astra H 2 button normal key.
And I have the same erase error. But with vvdi prog I can erase-it.... I can write in to it . So here are the photos .
you can program them use opcom if you have it bud
Lol mate. Used key from astra H and insignia , to other car with opcom.
Good joke .
I found that the black wire connection is different with renew diagram,please try the same as the diagram.then feedback,thank you
It is the same mate. I promiss. Look at the key.
It is just a point that is conected to the minus pad .
And same thing with astra h key . It works with vvdi prog, but not with vvdi keytool.
Does anibody have pinout for the ps2 connector?
Because I think it is a faulty cable.
As the remotes that are in the case work ok forr writing.
I considered of it,but I am not sure if they two locations are the same,I don't have the key. do you have other original key to test?
Yes. I have Astra H 2 buttons. I will make pictures today afthernoon .
Cloned Nissan micra 4d fine
on a cn2 chip!
So there's a good source of chips out there!
However i ordered a load of stuff of xhorse and it's taken nearly a month here!
And uk or Europe based distribution that people know of!
Now I am sure that something is wrong with the device.
Tried on peugeot 21676652 key. But still "Erase Error " The key is good key.
Iff I leave "brown" - sda unconected , the voltage on vcc and scl is rising up to 3.4 volts.
When I conect sda on board ( on all three off them ), the voltage stay's at 0.04 volts on all lines - Vcc -Sda - Scl . It does not rise to 3.4 when I press write.
L.E . Same key , Vvdi-prog, it has erased-it. I can write anything I want in to it.
KeyTool still have not fully working software
ENG version for EU was made too early , and now any feedback with issue is a priceless
Everybody know the storry , when Keytool was display first time , and after a year - we have EU version not fully working
Some people who work close with Xhorse have BETA version of Key Tool with more options / model to choice , but still not sable.
dorofteius (27th July, 2017)
