Page 74 of 176 FirstFirst ... 2464697071727374757677787984124174 ... LastLast
Results 1,096 to 1,110 of 2634
Thread: VVDI KEY TOOL
  1. #1096
    rob h's Avatar
    May 2011
    Quote Originally Posted by dorofteius View Post
    I really do not understand. Why would you do a copy for a id48 old as 15 years ?
    There are allot of tools at 50 E that can do that key.
    Copy id48 it would be usefull for mqb platform keys maybe. But otherwise , why would you need to do a copy id48 ?
    Just a opinion. Nothing more.
    Some cars dont let you pull the pin by obd. Like Fox or Beetle and some immoboxes.
  2. The Following 4 Users Say Thank You to rob h For This Useful Post:
    kleidaras (17th February, 2018), kluczbum (18th February, 2018), nagib (20th February, 2018), RIMKACHIP (17th February, 2018)
  3. #1097
    Oct 2016
    Scotland
    Quote Originally Posted by nagib View Post
    Today I had bad experience with 4D transponder. Tryed to clone Suzuki Alto 4D 65 from y. 2003 and keytool say calculate ok and cloning ok. Car sometime start when chip outside of key. Inside in the own place of key not start. Copyed tpx2 with another tool and everything was ok. Anyone with similar experience?
    I had a problem with copying a 4C chip few weeks ago in key tool. I used the special Xhorse 4c/4d chip.
    Set chip as 4c then copied onto the chip. It read ok in key tool, but not in VVDI2 or CN900 mini, and didn;t seem to want to start car.
    I reset the chip and copied onto this chip again and it worked fine.
  4. The Following User Says Thank You to WRX 14 For This Useful Post:
    nagib (18th February, 2018)
  5. #1098
    Quote Originally Posted by kluczbum View Post
    Keytool Me version
    I tried copy Id48 audi tt 99year
    Copy offline
    I make sniff and device calculate orginall key 40min and succes Key work
    How you make sniff with key tool?
  6. #1099
    Oct 2016
    Scotland
    When you need to use tool for sniffing it will tell you to do so, follow the instruction on screen.
    Simply put the tool antenna to the ignition switch
  7. The Following User Says Thank You to WRX 14 For This Useful Post:
  8. #1100
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by WRX 14 View Post
    true, also you can try not always very close to ignition , like key , maybe little left, little right , or more far from coil .
    need to try if not detect signal
  9. #1101
    metalik's Avatar
    Mar 2012
    Maartinj to sniff data its realy hard, today i try fiat id48, sniff data like you said, but i sniff only 4 time. Where is the problem?
  10. #1102
    Apr 2012
    London
    couldn't clone id46 HONDA BIKE key today -VVDI KEY TOOL after fail with sniffing- message on screen - "is it an original key?"
    job done on first attempt using TmPro2 and 46 clonner with CN3 transponder.
  11. #1103
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by metalik View Post
    you can use keytool or make a Electronic Key with NXP key and sniff data with that key
  12. #1104
    metalik's Avatar
    Mar 2012
    Its work only for id46.
    Quote Originally Posted by Maartinj View Post
  13. #1105
    newone's Avatar
    Oct 2016
    Quote Originally Posted by zyjekrc51 View Post
    i had similar problem with honda,when try to sniff could not hear fuel pump working,put original key off-on without sniff fuel pump worked,try again to sniff and all ok
  14. The Following User Says Thank You to newone For This Useful Post:
    zyjekrc51 (23rd February, 2018)
  15. #1106
    Aug 2013
    uk
    had same issue with id46 citroen after trying to sniff data had "is it an original key?" on screen.
    when i had lower version it would clone fine but took a while to sniff data had to leave 3-5cm away from coil.
    tryed many times with same issue. couldnt get it to sniff correctly. version 2.2.2
    If i helped.... please dont forget to press the THANKS + REP buttons .
  16. The Following 2 Users Say Thank You to thayer201 For This Useful Post:
    nagib (23rd February, 2018), zyjekrc51 (23rd February, 2018)
  17. #1107
    Greece
    today i make a clone for vw golf 2011. first i clone it on keyline chip and from this chip i clone it with off line function of vvdi.
    if have time ( kl cloning is 10 min and vvdi cloning 1 hour)
  18. The Following User Says Thank You to kleidaras For This Useful Post:
    newone (23rd February, 2018)
  19. #1108
    newone's Avatar
    Oct 2016
    Quote Originally Posted by kleidaras View Post
    i like your idea of a mule chip for testing purposes,lets hope that time period will improve,rw4 has 3-5 minutes,for me till now its for id46 and 4c 4d money saver,for remotes i prefer keydiy,other function wait to improve
  20. The Following User Says Thank You to newone For This Useful Post:
    kleidaras (23rd February, 2018)
  21. #1109
    Greece
    Me to. I use only for cloning.
    Στάλθηκε από το F3311 μου χρησιμοποιώντας Tapatalk
  22. #1110
    Greece
    I can't understand why vvdi the original chip can do only online. Keyline chip can do offline with sniff data from car. And China chip can copy direct with no sniff from car on 20 sec. All chip start Same car.
