Well, like you said Sleepyrz, the problem cured itself on the update to 2.4.2. I kept trying to go from 2.4.1 to 2.4.3 and didn't realize that 2.4.2 would download. Went to na after download, and did "identify tool" again. Thanks sleepyrz for making me doubt myself enough to back and check what I did again. Sent some well deserved rep your way.
Does 2.4.2 works? I had on my device 2.2.2 After update to 2.4.2 dissapeared SET and ENTER and came ERROR I came back to 2.2.2 Is it normal or there is sthg with my device?
EMCE159 (21st November, 2018)
You were wright, second time all OK
no prob broham
i saw the same exact thing when i got mine and was like eh? wtf????
then updated it to 2.4.2 and it went away....
i figured one of two things happened
when it updated it got a location from my computer and changed itself
or realized that particular serial number went to NA and it downloaded that version accordingly
camelgd (22nd November, 2018)
hi all member
last day have order key tool Eu on mk3.com . he send me ME version whats différence ? or have problem . possible change area version ?.
br
Envoyé de mon SM-A605FN en utilisant Tapatalk
I had the same probelm. Did you try to update?
I got my keytool in the ME version (It should have been 2.2.2) and after the first update, it was changed into the EU version. I do not know why, but it worked for me.
Kindly regards
buntbart
rojhat (23rd November, 2018)
rojhat (24th November, 2018)
If I have 3 separate VVDI Key Tools can all three devices be bind together through one single profile and share all bonus points/tokens?
And I know answer most probably is NO but - when they are all three bind together will the ID48 license also be shared among all of them, like it is shared among VVDI2 and VVDI KeyTool?
hi
I am new in the world keys
can somebody explain me?
key whit chip and wireles program as XN002 is only programmable one time or can be programmed several times?
many thanks inthe advance
morito (24th November, 2018)
but is renew immo and remote?
