Page 13 of 176 FirstFirst ... 3891011121314151617182363113 ... LastLast
Results 181 to 195 of 2634
Thread: VVDI KEY TOOL
  1. #181
    auto techniek's Avatar
    Mar 2017
    As far as I can see Ecutool is the seller
  2. #182
    ray-ray's Avatar
    https://americankeysupply.com/index....y+%28XHorse%29
    there here at the warehouse in the USA. My unit has been ship be here on Monday, Samic will be test long side of me.
  3. #183
    lidons's Avatar
    Feb 2011
    I, already have the English version V1.2.8 - now do tests.
    The truth is that it's very simple, few things come up on the men?.
    excuse my English, is the best.
  4. #184
    lidons's Avatar
    Feb 2011
    If anyone has the possibility to try these audi remotes.
    What kind of transponder do you use -(nxp7945ac)?
    I think it does not work.
    -8K0959754C
    -8K0959754J
    --And tried to record it on one I have, nxp7945ac and the remote does not work
    -8K0959754D - Works OK, the led of the remote, now question of trying on a car.
  5. #185
    Dec 2016
    Quote Originally Posted by lidons View Post
    Hello
    Could you tell me your seller
  6. The Following User Says Thank You to TERMINATOR1000 For This Useful Post:
    clintezra (24th May, 2017)
  7. #186
    lidons's Avatar
    Feb 2011
    Extra functions you have now. V1.2.8
    + Remote Renew
    -BMW-F.315*
    -BMW-F-434*
    -BMW-F-868*
    -BMW-CAS-315
    -BMW-CAS-868
    -8k0959754-C (Does not turn on the LED light of the remote) - Possibility Incorrect firmware
    -8k0959754-J (Does not turn on the LED light of the remote) - Possibility Incorrect firmware
    -8k0959754-D (LED light is OK) - Not tested yet in car
    -Hyundai (Do not detail model)
    * Sure some models like F series, will not work, like to passed with VVDIprog. And Audi see error in the (C and J).
    + Remote Prepare. V4
    -Iden KEYDIE - (PCF7947) None Remote.
  8. The Following 3 Users Say Thank You to lidons For This Useful Post:
    lupu_sandu (21st May, 2017), mikajna (21st May, 2017), neverquiet (22nd May, 2017)
  9. #187
    Jun 2016
    VVDI KEY TOOL updated to V1.2.9
  10. The Following User Says Thank You to Jerry523 For This Useful Post:
    Fallen (23rd May, 2017)
  11. #188
    Fallen's Avatar
    Quote Originally Posted by Jerry523 View Post
    Got a link to the download?
  12. #189
    electromech's Avatar
    Behind a large rock
    Can anyone confirm key renew function is working as its is not working with their other product VVDI PROG
  13. #190
    Bishop c4's Avatar
    chess board
    Quote Originally Posted by Fallen View Post
    Hello mate!! see attachment
    Best Regards
  14. The Following 3 Users Say Thank You to Bishop c4 For This Useful Post:
    Fallen (23rd May, 2017), kogej (10th June, 2017), lidons (23rd May, 2017)
  15. #191
    lidons's Avatar
    Feb 2011
    Which update has version 1.2.9?
    * Nobody knows? Because it does not indicate that there is newness.
    V1.2.8(2017-04-26)
    Improve update connections
    V1.2.7(2017-04-02)
    *Must be used 2.1.2 version upgrade software to update the firmware
    *Must be used [fixed] function to update the firmware
    1 fixed the remoter database damaged bug
    2 fixed the internal firmware damaged bug
    3 fixed the remoter clone bug
    4 added the calculation of hundyai keylessgo password
    V1.2.6 (2017-3-25)
    1, repair the 46 clone bug on part of models
    2, add TPX3(ID46) in clone transponder list
    3, add to view the ID46 detail data in TP-clone dialog(after clone success,press [right] button to check data)
    4, fixed bug of 4d clone
    5, fixed part of the fixed code clone bug
    6, add the special clone function for part of remoter
    7, add fixed code edit function
    8, add sort car brand in remote generate function
    9, fixed some UI bug
    V1.2.5(2017-2-23)
    1??support clone PCF7936/46,TIRIS-4D(40-bit) 4C,PCF7935(ID33 ID42),T5(11 12 13);
    2??support to edit 48 46 4d 7935 & common transponder
    3??support to make special transponder image such as TP23 TP24 ID33 ID40 ID42 ID44 ID46 ID60 ID67 and so on;
    4??support to generate hundreds of key model
    5??support to clone most of fixed code and Keeloq roll code remote key,such as pt2240,lx918,hcs30x and so on;
    6??support to measure the key's frequency & power
    *** I, as I will expect someone to update first. And say.
  16. The Following 2 Users Say Thank You to lidons For This Useful Post:
    Fallen (23rd May, 2017), fytfh (23rd May, 2017)
  17. #192
    Fallen's Avatar
    Default Don't update if you speak English only
    Ok, I wouldn't update your tool if you can only speak English as they have taken the English language option away for some reason.
    See attached photos.
  18. #193
    lidons's Avatar
    Feb 2011
    how that?
    Now if I update, and we will see what is happening,
    I hope you do not screw the machine
  19. #194
    lidons's Avatar
    Feb 2011
    You can not upgrade, version 1.2.9 is not yet available.
    To me, I did not leave it in Chinese, it's still in English.
    Also, the machine says that to update I must choose the lower version, V1.2.5. This step NOT done,
    Why should I download the version? Some error in v1.2.8. jejejej
  20. #195
    lidons's Avatar
    Feb 2011
    Has changed the version of (Remote Prepare) from previous version V4 to last V8.
