I am trying to Clone BMW ID44, PCF7935, is this possible or will it be possible soon?
I get read error when trying to identify ID44, Chip...maybe bug?
I updated to latest firmware, not sure if anything else I need to do maybe.
BRMTDI (18th September, 2017)
That would be amazing to be able to do, but at least I know it is not possible.....
Other Issue I am in the Middle of....I purchased
AUDI Q7 S8 KEY REPLACEMENT REMOTE FOB KR55WK45032 OEM TRANSMITTER 4E0 837 220 ELink, seller mentioned key is refurbished, chips renewed or replaced etc...this is for Audi A8 D3 Car, so I get the key and it is locked......
I took apart key and I noticed it has PCF7943,Key is Keyless Go.... I purchased some chips from ebay http://www.ebay.com/itm/5PCS-PCF7943AT-417-Encapsulation-SOP-16/131383945809?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2057872.m2749.l2649
Is it possible just to replace chip and key is new again ready to work, or do I have to wait until VVDI has solution to renew this key? Porsche Also used this same key, and Also VW Tourag, Kessey Module is Siemens 93C86.
If anyone has any experience with, unlocking these keys or matching locked keys, I would def appreciate it.... VVDI shows key is locked....so I think that is my main issue.
please fix this bug
i have try to unklock LAND ROVER YWX000071(315mHZ)Visteonafter renew the frequency have been changed to 434mhz
i tried the option YWX000061(434mHZ)Visteon to see if it was opposite it also give 434mhz
my key is 315mhz... pleas fix the bug because after renew its became 434mhz... maybe you have put same two file but with different name
IF MY POST WAS HELPFUL DON'T FORGET TO GIVE ME LIKE AND REPUTATION... THAT WILL KEEP US HELPING OTHER'S
one possibility:your key inherent frequency it's 434mhz,renew doesn't change the frequency.
PierreTheron1 (29th September, 2017)
I tried Hyundai proximity key, it unlocked but no frequency.
What a tool.... Any update soon to fix many problems?
Sent from my XT1650 using Tapatalk
I have renew hyundai smart key without any problem
Toyota smart key i have use special function to unlock it. I have got unlocked ok but the led light did not blink 3 time in the smart key .
i have try with cn900 and the light blinked 3 time after the unlock
@fixanycar please make sure you are refering the v2.0 wiring diagram.and tried twice as RIMKACHIP advised?what's the result?
@eliaselias please take both side PCB photo of your key,let have a look
Hello louis21 in futher any updates with renew key fobs (7941) ??
NO PASS
I bought a whole lot of Remote keys for the VVDi 2 and now we tried using them with the VVDI KEY TOOL to generate a remote and it says REMOTE HARDWARE VERSION OUTDATED.
SO why can these remotes not work with the VVDI Key tool?
BTW I tried the AUDI 8P0 (Audi A3) remote on VVDI2 and it generates but the car does not recognise. I generated the same model using KEYDIY and their remote and it worked on the car. Please fix this bug....
