This tool should be making up here mind.
Iff you update somethings are not working. Iff you do not update , other things are not working.
I have the files for peugeot and opel, and they still cannot implement .
I don't understand anymore.
lalaina74 (21st November, 2017)
Hi have you test to downgrade 2.0.6 and after remote wire works ?
Envoyé de mon iPhone en utilisant Tapatalk
Yes. Then upgrade to 2.08 and not work, and again 2.06 an work again.
So mine will remain to 2.06 .
RIMKACHIP (21st November, 2017)
because different country maybe some remote option never used, so we delected few datas to make device option more simple and save memory size.
if you need to add some options compare to other version, you can post here(need to know current version and exactly option) then we can update and add.
lidons (21st November, 2017)
dorofteius (21st November, 2017)
It canot generate wired remotes with 2.08. None. Not for any maker and not for any remote model
Error code 80 , afther 1% .
I have Ds stile , A6L stile and the remotes that arrived with the tool.
Only wirless remotes work .
On 2.06 no problem generating wired remotes.
Failed to copy transponder Kangoo Mk1Ph2 ID46 Would not sniff
Failed to copy transponder Trafic ID46 Would not sniff
Wanted to generate old vw sharan remote 7M3959753F clicked sharan 7n but flashes 5ko-837-202-e on top of screen
v2.06
