Results 1 to 10 of 10
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Default W211 dash virgin pls
    hi,
    pls for virgin dashboard from Benz W211
    eeprom Atmel 24C16 there
    thx
    :: Atmel.24C16.W211.A211.540.57.11.eeprom.rar
    P.S. no need change km value to 0km this i can do self need only virginise this dump to use this dash in other W211 with teach through EZS unit
    many thanks to friend kevfield
    workshop
    you can simle teach to eis if you 0 km have
    odo-dev.mode-ansteuerungen-writte-key id
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by mercis View Post
    only 0km value is enough to teach in other car ? i think will be better to have eeprom content as virgin....
    workshop
    yes,you can odo learning to eis.upload dump and writte key id with dev.
    • File Type: rar 0.rar (944 Bytes, 149 views)
  5. The Following 2 Users Say Thank You to mercis For This Useful Post:
    daxxer (19th October, 2016), hussamultratec (11th January, 2020)
    volismb's Avatar
    Feb 2016
    Quote Originally Posted by daxxer View Post
    yes, for all FBS3 cars it is enough to set the odo to 0 to teach the instrument in another car
  7. The Following User Says Thank You to volismb For This Useful Post:
    daxxer (20th October, 2016)
  8. #6
    daxxer's Avatar
    Apr 2014
    in circuit :-)
    Quote Originally Posted by volismb View Post
    i don't know how, but for this car W211 this not enough...set km value in cluster to zero not help to teach the IC to EZS, because is teached yet, then not possible again...and can't teach the km value to the EZS....
  9. #7
    volismb's Avatar
    Feb 2016
    The synchronization is done by SSID. Read the SSID with Star and put the same SSID in the dash and job done
  10. #8
    Nov 2016
    Can you tell or show a picture of the SSID in the dash file please ?
  11. #9
    Aug 2019
    Adress its 40-43
  12. The Following User Says Thank You to Aeromechanic For This Useful Post:
    zmsautogas (14th February, 2020)
  13. #10
    Oct 2019
    Hi Gents!
    Same issue. Does it happen quite a lot, loosing eeprom content during T15on? my 24C16 is empty...
